no SFT40 5000K available currently.
You can put 21*1.5mm O-rings on the outside of the 18650 battery, but the 18650 battery is too short to fit.
i dont have suitable driver for FC40 currently
Simon,
Thank you so much for your continued interaction with us. It is much appreciated. I’m looking forward to those 26800 extensions. If I may, what are the odds of getting something like an L2 with a larger head? It could be used to make a compact super thrower with something like one of the Kaidomain 86mm reflector (or something around that size). I’d be very happy with just a new head or adapter for a larger reflector too, if that would work and be more feasible.Single 26800+~90mm reflector sounds awesome to me!
uh ,the bigger head for SBT90.2?
Since the mobile phone does not use fixed parameters, SBT90.2 looks a little dark from the picture, the picture is for reference only.
3X21A SST40 (P2 bin),6800LM,142.5KCD,755 meters ,aliexpress price $59.19
3X21A SFT40 (N5 bin),5400LM,265KCD,1029 meters ,aliexpress price $65.61
4X18A SBT90.2,5400LM,314.7KCD,1122 meters,aliexpress price $78.54
I’m going to have to complain just a little. Those are teaser pictures. Can you give us a little better photos, please. You know reflector, threads, inside the body tube.
Simon Mao:Since the mobile phone does not use fixed parameters, SBT90.2 looks a little dark from the picture, the picture is for reference only. 3X21A SST40 (P2 bin),6800LM,142.5KCD,755 meters ,aliexpress price $59.19 3X21A SFT40 (N5 bin),5400LM,265KCD,1029 meters ,aliexpress price $65.61 4X18A SBT90.2,5400LM,314.7KCD,1122 meters,aliexpress price $78.54 !https://live.staticflickr.com/65535/51250060712_3c617fd222_b.jpg!
yes, reflector please! And yes, battery tube too
Question is the SFT-40 the domeless version of the SST-40? Same voltage and footprint as the SST and XML?
Is the SFT-70 the Luminus domeless version of the Cree XHP-70 same 12 voltage and footprint as the XHP-70?
Anyone have the Spec sheet for those leds?
Thanks
Superstocker:Simon,
That or Osram. The Kaidomain has a large opening for the sbt90.
Thanks
See post #4861
Thanks
Luminus’ numbers refer to the LED’s emitting area. SST-70/SFT-70 means 7 square mm. SST-20 means 2 square mm.
The 7 in cree’s XHP70 means a 7mm by 7mm pad footprint.
I don’t believe that’s correct. The SST-70 is a 5 sq mm package. The emitting area is only slightly larger than the SST-40.
It should be correct as the SST70 consists of four SST20 led dies which are 2 square mm each, for a total of 8 square mm. You need to consider that the footprint is 5x5 mm, so 25mm². 7mm² is 2.65mm at each side so it fits well.
But you are right, 2.65mm die lenght for the SST70 and 2mm for the SST40 is quite a small difference.
A 5mm square is 25mm². SST-40 certainly is 4mm² (2mm*2mm). Square root of 7 is ~2.65. So yes, the side length it’s only slightly larger, but area nearly double.
Ah, I see. Thanks
Aux LEDs serve me 2 purposes:
- they indicate voltage (by changing colour)
- they tell me whether the light is locked out (If they are dim, the light is locked out)
Both things are of huge importance to me.
But at the same time:
- These are the fanciest indicators but neither the cheapest nor the simplest ones. A switch RGB LED would work exactly as well.
- My fork of Andruil puts heavy emphasis on lockout. Maybe a simpler Convoy UI doesn’t need it at all
So…I somewhat agree with what was said before, AUX lights don’t really fit the Convoy’s quality at budget price niche. At the same time I find voltage indication to be of huge value and I suggest Simon that you evaluate options to make it accessible to customers.
Simon:
- I can't find any trace of a 3x21A flashlight, yet posts date back to September on it being in production. Am I missing or mis-understanding something?
- You listed a 3x21A available with a P2 bin SST-40, are those available or will be available for purchase separately, and are they 6500K or 5000K?
Thanks!
Voltage indicator is always useful.
More than Aux Leds and considering that Emisar don’t want made a quad light with adjustable temperature, I wish for quality LEDs bin below BBL that provide a wide range temperature like Nichia E21A start from 2000k to 5000k
And a regulated Driver with smooth ramp with each channel adjustable from sublumen and No PWM
Simon:
I can’t find any trace of a 3x21A flashlight, yet posts date back to September on it being in production. Am I missing or mis-understanding something?
Thanks!
Flat-to-Top head plastic adapter for battery is being produced, and it will take about two days.
interested in “P2 bin SST40” To purchase bare? Would we leave a “note to seller” for P2 bin, when buying sst40 on your store?
Same here - meant to ask if the P2 SST-40's can be bought bare, and what tint they are, thanks!
it’s P2 bin in stock currently ,There is no need to specify it in the remarks.
Same here - meant to ask if the P2 SST-40’s can be bought bare, and what tint they are, thanks!
BA bin,
But the batch update is fast,
