It should be correct as the SST70 consists of four SST20 led dies which are 2 square mm each, for a total of 8 square mm. You need to consider that the footprint is 5x5 mm, so 25mm². 7mm² is 2.65mm at each side so it fits well.
But you are right, 2.65mm die lenght for the SST70 and 2mm for the SST40 is quite a small difference.
A 5mm square is 25mm². SST-40 certainly is 4mm² (2mm*2mm). Square root of 7 is ~2.65. So yes, the side length it’s only slightly larger, but area nearly double.
they tell me whether the light is locked out (If they are dim, the light is locked out)
Both things are of huge importance to me.
But at the same time:
These are the fanciest indicators but neither the cheapest nor the simplest ones. A switch RGB LED would work exactly as well.
My fork of Andruil puts heavy emphasis on lockout. Maybe a simpler Convoy UI doesn’t need it at all
So…I somewhat agree with what was said before, AUX lights don’t really fit the Convoy’s quality at budget price niche. At the same time I find voltage indication to be of huge value and I suggest Simon that you evaluate options to make it accessible to customers.
Voltage indicator is always useful.
More than Aux Leds and considering that Emisar don’t want made a quad light with adjustable temperature, I wish for quality LEDs bin below BBL that provide a wide range temperature like Nichia E21A start from 2000k to 5000k
And a regulated Driver with smooth ramp with each channel adjustable from sublumen and No PWM
Simon, have you ever made the S2+ in brass (yellow copper)? I don't remember ever seeing or hearing about one but I would love to own it someday! I do remember the smooth red copper one a few years ago but did not buy.
I know brass is slower to machine than aluminum and more expensive but I think it would be a very nice option. The couple of brass lookalikes from other companies I have seen have been poor quality.
Yes he did 2 batches , or was that copper? (The 2 batches which were not compatible with eachother due to different threads)
Maybe there can be a 3rd batch?
