Hmm, I’m pretty sure the solder on the B is excess that came from under the ring… They must have applied a little bit too much solder paste or something. About the ring I don’t really get what you mean unfortunately…
Does anyone know if the extra spare parts (additional o-rings, button cap, USB connector cap) are included in the normal (“without-battery”) option? Or only with the “with-battery” option?
My first one was ordered w/o cells and came with the spares you asked about. That was from the first batch but I don’t see any reason that would change as other lights I have purchased w/o cells have included the spares as well.
I will, sooner or later Ordered one last Friday.
BTW, I also asked Sofirn some technical questions prior to making the purchase. Which they answered quite promptly:
Is it possible to use the power-bank function while the lantern is lit? >> yes
Is it possible to charge the lantern, while it is lit? >> yes
Is it possible to operate the lantern directly from an external (Type-C) power source, while no batteries are installed? >> yes
Is maximum brightness (maximum LED-driving current) achievable in any of the above scenarios? >> yes
If those replies are accurate, it is pretty damn impressive. (Although I admit, I am not sure how I should interpret the answer of “yes” to the 4th question: “yes, in all of them” vs. “yes, in some of them” ) I guess I’ll have to wait and see.
Do I remember correctly that flat top NCR18650GAs are also suitable for this lantern (i.e. it is not necessary to go for its less common and more expensive button-top counterpart?)
(Because the flat NCR18650GAs also have a slight “bump” at their positive contact.)
Do you know of any reliable sellers with reasonable prices in the EU? Unfortunately NKON.nl don’t seem to have either variant in stock now
Has anyone asked Sofirn if they are willing to provide the new driver board, with power bank function, for someone who already has the LT1, to replace the old one?
Yeah, but Sofirn has been offering to email a coupon code to BLFers for an even better price, $62.24 including batteries, for most of this month. linky
You need button top, or the battery fouls components on the driver board as I recall, details are in the thread already if you use thread search (I know what you mean about the NCR bump but I think it would still catch)
I can use flat top batteries (Panny 18650B’s, 30Q’s, and various laptop pulls) in my 3 LT’s (part of the original buy) without any issues. It probably comes down to manufacturing tolerances on the LT’s.
It’s more of an issue of the top of the wrappers snagging on the POT (inside of the copper ring). It’s useless and can be removed as several people have done with their LT’s.
I suppose the wrappers can also be damaged if the copper ring has burs on it but those can be sanded out if need be.
The tops of the POT on my LT’s are low enough that they don’t snag on and damage the wrappers on my cells.
