> The only LED emitter quantity number that really does not work (and I think we all know why) is 2.
does not work why?
Here are a few two LED lights I found by searching:
Fenix LD50
Sunwayman D40C
LED Lenser 880095 X14
KLARUS-XT20
Nitecore TIP SE Dual
Nitecore TIP2
Mecarmy PS14
zoulas
(zoulas)
June 21, 2021, 3:45pm
4
flightless22:
If mean that weird Vokka light, yeah.
A better thought out design is Boroiut D25 and WurkoH20, and while it’s technically 4 emitters IF25 works fine with just 2 (tint ramping). I know there’s many others.
I meant a flashlight as in handheld. The headlamp works with two emitters because its always horizontal .
zoulas
(zoulas)
June 21, 2021, 3:49pm
5
jon_slider:
does not work why?
Fenix LD50
Sunwayman D40C
KLARUS-XT20
Nitecore TIP2
Lumintop made one too, but I have not found it yet.
You are technically correct. The implementation of those lights is weird at best as you are forced to hold the light a certain way.
I think you will agree, probably less than 0.001 of one percent of the lights out there have two emitters. Its a true odd ball.
I am not sure how they look like, but here are 2 lights with 2 leds each: Mecarmy PS14 and Amutorch AX3
Scallywag
(Scallywag)
June 21, 2021, 3:56pm
7
There’s always that one weird Amutorch that was available as either two-emitter with reflectors, or a weird quad (spaced wide, and with aspheric lens)
MascaratumB:
Mecarmy PS14
thanks thats the one I was looking for
pic is a link
mecarmy:
You must only mean 1 special case of 2 emitters. Do you mean when there are 2 identical side by side emitters? Because there are a whole lot of lights with a pair of different emitters.
1 white and 1 aux color is pretty common. So is 1 flood and 1 throw . Often an emitters points forward while the other is an anglehead so the light can be both . Having a pair of emitters greatly increases the flexibility of the flashlight and it is pretty popular.
zoulas
(zoulas)
June 21, 2021, 4:41pm
10
I meant primary not aux.
Also most of the lights mentioned are two single emitters in one unit.
goshdogit
(goshdogit)
June 21, 2021, 4:53pm
11
I had to make this one myself.
See where you’re going and where you’ve been—simultaneously! And at the same time!
Yes, it works! The battery carriers are back to back and insulated from each other.
goshdogit
(goshdogit)
June 21, 2021, 4:52pm
12
Lupine makes a couple side-by-side models. Hide your wallet.
Not space-efficient.
1 emitter, you can size the head/reflector up/down as you want.
3, 4, others, you size the head up/down, and stuff the LEDs regularly in a circle.
5 would be wasteful (quincunx shape) unless the center LED’s reflector/lens is reeeeeally small.
2 is by necessity a 2:1 rectangle. If you stick ’em in a circular head, there’s wasted blank space above/below the side-by-side LEDs.
Unless you want to buy a 2-emitter light at the Darth Mall.
Only reasonable 2-emitter light would be with 2 cells side-by-side as well. And those are all weirdo designs, so it’s not surprising it’s rare.
goshdogit
(goshdogit)
June 21, 2021, 5:42pm
14
Lightbringer:
(quincunx shape)
Good points, LB, and you taught me a new word!
zoulas
(zoulas)
June 21, 2021, 5:58pm
15
So, from Algebra 101, we can conclude if A=B and B=C then A must equal C no?
Similarly , if LB taught you, then who taught LB? Its a mystery . LOL
If you go back far enough, you will find a caveman holding what seems like a flashlight. On it will read “Ever Light Bringer Edy.”
zoulas
(zoulas)
June 21, 2021, 6:17pm
17
Yokiamy:
exactly
That would be two single emitter lights in one.
In a pinch, I would “palm” a headlamp, so youse can use a D25 like that.
Scallywag
(Scallywag)
June 21, 2021, 8:14pm
19
Lightbringer:
The Darth Mall.
I think that’s your best one yet.
goshdogit
(goshdogit)
June 21, 2021, 9:49pm
20
I chuckled, and I don’t even like Star Track.
That’s where I got my last light.
Turned it on, almost got a 2nd bellybutton.
