I had to make this one myself.
See where you’re going and where you’ve been—simultaneously! And at the same time!
Yes, it works! The battery carriers are back to back and insulated from each other.
Not space-efficient.
1 emitter, you can size the head/reflector up/down as you want.
3, 4, others, you size the head up/down, and stuff the LEDs regularly in a circle.
5 would be wasteful (quincunx shape) unless the center LED’s reflector/lens is reeeeeally small.
2 is by necessity a 2:1 rectangle. If you stick ’em in a circular head, there’s wasted blank space above/below the side-by-side LEDs.
Unless you want to buy a 2-emitter light at the Darth Mall.
Only reasonable 2-emitter light would be with 2 cells side-by-side as well. And those are all weirdo designs, so it’s not surprising it’s rare.
So, from Algebra 101, we can conclude if A=B and B=C then A must equal C no?
Similarly , if LB taught you, then who taught LB? Its a mystery . LOL
If you go back far enough, you will find a caveman holding what seems like a flashlight. On it will read “Ever Light Bringer Edy.”
exactly
exactly
That would be two single emitter lights in one.
In a pinch, I would “palm” a headlamp, so youse can use a D25 like that.
The Darth Mall.
I think that’s your best one yet.
I chuckled, and I don’t even like Star Track.
Lightbringer:Unless you want to buy a 2-emitter light at the Darth Mall.
The Darth Mall.
That’s where I got my last light.
Turned it on, almost got a 2nd bellybutton.
Scallywag:I think that’s your best one yet.
Dr Smith is displeased.
The guy with the elf ears who flashes gang signs? I thought his name was Dr. Spork.
Dr. Spork with his 1-emitter light that he got at the Darth Mall (in the Star Track Universe.)
One of the first pop can flooders, if not the first, the Niwalker MM15 2 x MT-G2, is a two emitter light. I waited until November, 2014 to latch onto it. The review by Selfbuilt mesmerized me for weeks. So many happy memories!
Click here for detail - NiWalker MM15 Coupon - DualMTG2 Technical specifications Light output / runtime Mode 1 : 6 lumens Mode 2: 180 lumnes Mode 3: 450 lumens / 24 hrs Mode 4: 880 lumens / 9 hrs 25 mins Mode 5: 1950 lumens / 5 hrs 17mins Turbo: 5233 lumens / 2 hrs 10 mins Max beam distance: 280 meters Peak beam intensity: cd: 19.600 [image] [image] [image]
Manker ML03
https://www.aliexpress.com/item/1005001769454212.html
RovyVon E200 series
The Angel Eyes E200 series includes 3 models – E200u, E200s, and E200r. The E200u uses a dual-chip LED which makes UV-C (270nm) and UV-A (390nm-400nm) available on the same LED. The E200s uses 6500K cool white LEDs for both front and sidelight. And...
Price: USD 79.95
That brings back memories indeed! Still got a couple of these Niwalker MM15s - one from Vinh - and successfully dedomed my first MT-GT leds with this light to give a bit more throw.
richbuff:One of the first pop can flooders, if not the first, the Niwalker MM15 2 x MT-G2, is a two emitter light. I waited until November, 2014 to latch onto it. The review by Selfbuilt mesmerized me for weeks. So many happy memories!
Ooh, I hadn’t seen that before but I kind of want one. I love the MTG-2, and two of them must be better than one.
