Is there currently any usb tester better than the power z km001?
focusing on the amperage and voltage data acquisition capabilities in the pc software.
Many computer and cell phone technicians use this usb tester to measure the consumption of a device that is being repaired, but the software is never well translated at least into English
and it would be good more precision and samples per second(max 1000 sps ).
This ultraportable device is not meant to take 1000 measurements per seconds. One is fair enough. I would recommend you a bench multimeter or digital oscilloscope. A thousand accurate measurements per second require high rank equipment.
Now could update it successfully the TC66C to firmware 1.15. What happened had the Windows software installed to ‘C:\Program Files (x86)\RuiDengUSBMeter\RuiDengUSBMeter.exe’, which requires administrative permissions to run from there. After enabling the .exe to run as administrator now works perfect: 固件升级完成,等待设备有自
Yeah you can, but the output will be most likely fixed at 5V, and depending on the cable it may or may not transmit the power to the other end, some USB-C cable requires authentication before allowing power transfer.
Regarding the POWER-Z FL001 SUPER, is there any way to force the meter to start in English? As is, every time I plug it in I have to change the interface from Chinese to English, which is mildly annoying despite it not being that difficult.
Also, is there a firmware update that offers support for Apple’s charging protocols?
*For anyone searching for information on changing the language: double-click the large rocker-style switch, then double-click it again. English! (Unless you accidentally single clicked it the second time. In which case, enjoy your newly rotated display. In Mandarin.)
Have problems with the TC66C app, on Samsung with Android 12: says “Storage permissions are not open” and “Storage error” whenever I click on SHARE.
Anybody else having the same issue with Android 12, Samsung or not?
TheHWcave has some great in depth looks and testing of various USB meters. i learned a bunch about my UNI-T UT658 USB testers play list
i don’t know why he has so few subscribers? i think he’s fantastic.
