Two Emitter Flashlight
In a pinch, I would “palm” a headlamp, so youse can use a D25 like that.
The Darth Mall.
I think that’s your best one yet.
I chuckled, and I don’t even like Star Track.
That’s where I got my last light.
Turned it on, almost got a 2nd bellybutton.
Dr Smith is displeased.
The guy with the elf ears who flashes gang signs? I thought his name was Dr. Spork.
Dr. Spork with his 1-emitter light that he got at the Darth Mall (in the Star Track Universe.)
One of the first pop can flooders, if not the first, the Niwalker MM15 2 x MT-G2, is a two emitter light. I waited until November, 2014 to latch onto it. The review by Selfbuilt mesmerized me for weeks. So many happy memories!
Manker ML03
https://www.aliexpress.com/item/1005001769454212.html
RovyVon E200 series
https://www.nealsgadgets.com/products/amutorch-at40-xpg3-nichia-xpl-hi-led-flashlight?_pos=5&_sid=8cec21b1f&_ss=r
That brings back memories indeed! Still got a couple of these Niwalker MM15s - one from Vinh - and successfully dedomed my first MT-GT leds with this light to give a bit more throw.
Ooh, I hadn’t seen that before but I kind of want one. I love the MTG-2, and two of them must be better than one.
Again, both are single emitter lights. 2 in 1 lights.
I think what the OP meant was something like this -
free image hosting reviews
I now understand that these aren’t the kind of lights zoulas is after, but I can’t help posting this MAXTOCH OWLEYES W1 I just discovered.
I know that this isn’t the light OP is searching for, but this thread seems like the right place for it - the Warsun X608 with 2x Osram P8 and a side-firing COB and inbuilt battery + powerbank function.
16$ with a code from Fin17: Archive topic - Banggood & Fin17
I have this light and I really like it.
It’s not easy to disassemble, but the batteries are really 4Ah, the light colours are all not blueish, the UI is good and the light gets warm after a short amount of time, to the LEDs are all cooled.
Only negatives are the micro-USB port instead of USB-C and that it’s not disassembleable without being destroyed.
Perfect for testing out if that formfactor is suitable for you.
I should have said , two emitters, one reflector. Many people have been posting, milti emitter, multi reflector, this is not what I meant.
You could change the title of the thread to: Two Emitter One Reflector Flashlight.
So are you excluding things like the Amutorch with the double-reflector inside an otherwise normal-sized head? Because I think that’s the perfect example of what you said doesn’t really make sense. Lots of wasted space.
