1*LED+1*COB 7-Mode 800LM LED Flashlight
pure white laser & red light / 1*18650/1*26650 / power bank function / IPX4 waterproof / power indicator light
Head diameter: 68mm
Tail diameter: 35mm
Indicator light: 4 power indicator lights 25–50–75–100
Head diameter: 68mm
Tail diameter: 35mm
SMILING SHARK E513 Four-color Atmosphere LED Flashlight w/ Focus Zoom
4*LED / 5-mode / 800LM / pure white+RGB / 1*18650 / w/ diffuser filter / built-in 4 wicks / removable light sleeve / water resistant
Head diameter: 30mm, Voltage: 3.7-4.2V
Convoy S2+ 1*Cree XM-L2 T4-7A 499-Lumen 2-Group 3/5-Mode LED Flashlight
1*18650 / AMC7135*4 / lanyard
Reflector diameter: 1.8cm
Head diameter: 2.4cm
Tube diameter: 2.4cm
Tail diameter: 2.4cm
Beam range: 50-100 meters
Lanyard length: 13cm
Voltage: 3-4.2V
To switch mode group: Switch to low mode and wait for 5-10 seconds. As soon as you notice the flashlight automatic blinking, turn off and then turn on, the mode group is then toggled
1*LED 5-Mode 5000LM LED Flashlight w/ Focus Zoom
pure white / 2*18650/2*26650 / USB output / IPX4 waterproof / window breaker
Head diameter: 60mm; Tail diameter: 36mm
1*LED+1*COB 5-Mode 2800LM LED Headlamp
pure white / 3*18650 / hand wave activated / USB output / rear red warning light / power display / IPX5 waterproof
2PCS Solar Powered Up Down LED Garden light Wall Lamp
2*LED / warm white / light sensor / IP65 waterproof
Solar panel: 2V/200mA polycrystalline silicon solar panel
The following environments are not suitable for installation:
Glass room (Although there is sunlight, the glass is blocked, which affects the intensity of light. It affects battery charging)
Monitoring area (the monitoring area is not suitable for installation, the monitoring has infrared rays. It will affect the brightness of the light)
Under the tile eaves (the area where the lamps are installed must not have tile eaves, trees, wires, etc.)
Short exposure time (the area where the solar lamp is installed must be exposed to sunlight for at least 6 hours)
SingFire SF-348 LED Flashlight
authentic / Cree XP-E R3 / 1-mode / 180LM / 1*10440/AAA / clip
Reflector diameter: 9mm
Head diameter: 12mm
Tube diameter: 12mm
Tail diameter: 12mm
Beam range: 30 meters
Working voltage: 1.5-4.2V
2PCS SMILING SHARK 617A LED Flashlight
1*LED / 3-mode / 240LM / pure white / 1*18650 / USB rechargeable / power bank function / IPX6 waterproof
4PCS SMILING SHARK 612 EDC LED Flashlight
1*LED / 4-mode / 400LM / pure white / 1*14500 / clip / IPX6 waterproof / anti fall
Voltage: 3.7-4.2V
Head diameter: 22mm
Tail diameter: 22mm
1*LED+1*COB 4-Mode 1000LM LED Flashlight w/ Focus Zoom
pure white / 1*18650 / clip / magnetic adsorption / water resistant
Head diameter: 45mm; Voltage: 3.7-4.2V
1*LED+16*COB 4-Mode 700LM LED Flashlight
pure white / USB rechargeable / IPX3 waterproof
Head diameter: 60mm; Tail diameter: 35mm
Authentic XTAR T2 Mini EDC LED Flashlight
1*Cree XP-G3 S4 LED / 7-mode / 650LM / pure white / 1*10380 / lanyard
Head diameter: 38mm
Dear valued customers,
Get ready to grab the best products from variety of ranges at affordable price from FastTech! It is time to celebrate the Independence that we enjoy from the hands of our freedom fighters.
————————- Independence Day Site-Wide Coupon ———————————
Offer: Site-wide 10% off
Valid Date: July 3, 2021 - July 4, 2021 (UTC-6)
Coupon Code: IND2021
SMILING SHARK ES03 EDC LED Keychain Flashlight
3*Luminous SST20 LED / 6-mode / 3000LM / pure white / 1*18350 / IPX8 waterproof / multi-stage heat dissipation / crush & drop resistant
Convoy S2+ LED Flashlight
1*Luminus SST40 LED / 4-mode / 1800LM / pure white / IPX8 waterproof / 1*18650 / w/ lanyard
Drive: 7135*8
Voltage: 3-4.2V
Head/Body/Tail diameter: 24.1mm
New Arrival Convoy M21D LED Flashlight
1*LED / 12-group / 4300LM / warm white / 1*21700
Voltage: 3.7-4.2V
Head diameter: 55mm
Tube diameter: 28mm
With low voltage protection and temperature control protection
Mode operating instructions:
Click button —> flashlight is on with last brightness —> press button, brightness ramping up -> release and press button again, brightness ramping down
Flashlight off, press button —> moonlight mode 0.01a (0.2%) [this glow will not be remembered]
Flashlight on or off, 2-click the button-> 100% turbo
Flashlight off, 3-click button->strobe
Flashlight off, 4-click button —> tactical mode, only 100% ,4-click button again to exit tactical mode.
Flashlight off, 5-click button —> voltage detection (* means “flash”, * pause* means 3.7V, )
Flashlight off, 6-click button —> normal ramping mode switch for 4 modes 1–10–40–100
Flashlight off, 10-click button —> lock mode, flashlight will flash once under any operation, which means flashlight is locked. 10-click button again to exit lock mode, please note that this is the only way to unlock.
Just ordered the 3X21A SFT40 using your coupon, thanks for a good deal!
AlexGT
Dang, should have waited. Ordered mine from Convoy for like $72 after taxes, etc. Using the BLF coupon code, free shipping, it's $9 cheaper here.
