My order is placed. Thank you Jackie for the HSMXMNUEXN4N code, used it just now and it works for $3 off.
I also put the note in the remarks alisofirn for diffuser. Thanks!
Hi Jackie,
Are you selling the Sofirn SD05 version with SST 70 LED Without the Advanced Temperature Regulation stepdown function on your Aliexpress account?
Also please update the product description text for the SD05 as it still mentions “* CREE XHP50.2” when it is already SST 70 LED.
Thanks!
The 5$ coupon don’t work for me
HI SD05 now all use XHP50.2 now ,SST70 LEDs no stock
$5 coupon already been used all, please try $3 code ,still have some left
Hi Jackie,
I’m planning to get an IF25A from Aliexpress
I recently saw from reddit that Wurkkos HD20 pocket clip and magnetic tail cap will fit IF25A, can comfirm that? And, how can I purchase them on Aliexpress?
Also left a message for you guys in Ali chat
Thanks
Yes, it will fit IF25A, here is the link for clip :https://www.aliexpress.com/item/1005002870376003.html?spm=5261.ProductManageOnline.0.0.1f804edfUKCaZG
free shiping if order together with the flashlight
Great! Thanks for the quick reply.
Does the HD20 magnetic tail cap fit too? If so, can you please provide me with a link also?
Thanks
Hi Jackie,
Right now, do you have a SD05 version with XHP50.2 without the ATR (Advance Temperature Regulation) function?
Also, when is SST70 LED available again?
Thanks....
SST70 LEDs no stock now, when LEDs in stock could assemble some more SST70 version. Right now all with XHP50.2 and ATR
pity, just tried, HD20 tail not suit for IF25A
The coupon does not work, can I renew it?
Shipping to my country is not free anyway …
Just purchased a LT1 Q8, thanks for the code.
I’m waiting on that new HS05 to become available with Samsung 4000K and/or 5000K CRI 90, Is that already in the planning? I want it but not in Cool White like it sells now.
now with LH351D 5000K
SC31T New arrival ,usb c rechargeable tactical flashlight with SST40 2000lm output
Hi
Code not working for HS05
Thanks
check again, the code is A13OI8EN7ZFG, please try again
