Put it a bag of rice like people do with wet cellphones, it will pull moisture. you can use an pair of stockings to hold the rice and put both in gallon zip lock for a few days.
HTH
Keith
HTH
Keith
ReFrigerator is low humidity.
What are the changes / improvement (?) of Sofirn C01S from its predecessor C01? The latter is only about US$6, whereas the former is now selling for about US$9 in Sinigapore’s Shopee and Lazada websites.
They are two completely different flashlights.
The C01 is a low power flashlight with 5 mm LED without lens or reflector and a single mode.
The C01S is a high(er) power flashlight, SMD LED, TIR lens, and two to three modes.
Do c01s already have three mode? I thought only c01r got 3 mode.
c01 is one mode, 3200k High CRI 5mm LED, 7 lumen single mode
c01s is two mode low high, no memory, 4000k sst-20
c01r is 3 mode red 660nm
afaik c01 series is discontinued… buy what there is, dont expect another batch…
Might need to get additional c01s. Potted is green and black only right?
The non-ano silver C01S is not in stock for some time
80 PCS Small Magnets, 5x3mm Mini Magnets Round, Tiny Magnets Small Magnets for Crafts, Strong Office Magnets for Whiteboard, Fridge, Home, Kitchen, Office Amazon.com would these be good?
Those are the right size. The strength and quality of the neodymium magnets can vary a good bit from my experience with them.
There is a 5×5 size would that have more sticking power even with the same surface area for sticking?
If you don’t mind that it protrudes about 2mm past the end of the slot of the CO1S
Edit - I would stick with the 5×3mm, even the weak ones had just enough strength to hold the CO1S on a vertical surface.
some of mine
Convoy actually has 5mm diameter x 3mm thick magnets on their Aliexpress store. He advertises them as temporary buttons for flat top batteries, so strength might not have been a priority in sourcing them, but Simon generally sells quality stuff, so I’d personally try his magnets versus a random Amazon seller.
some of mine
So I’m not the best at physics but that would be the ultimate test right? It would be easier for them to hang upside down?
Yes, it’s easier to get them to hang upside down than to resist sliding down a smooth surface or peel off because of the center of gravity being far from the attachment point.
I got a couple of C01 for the kids as a bribe, and now as an additional bribe I’m tempting them with phosphorescent tubes for the back. Any recommendations?
For myself I also got a C01/C01r/C01S trio. Really happy with them. Anyone has any backstory how to Red version came about as it seems a bit of an outlier. I would love to have the options to get similar in different colours … because … why not.
Barry came up with the red LED when Sofirn decided to reissue the C01 using rngwns LED. He warned that the beam is not very good and even showed a beamshot, but no one complained and some asked for it. At that time 670 nm was hip due to a medical paper.
Edit: was talking about the red C01, not the C01R.
Looking for guidance. I have seen references to using a 10440 cell in a C01s. What are the implications? Poof? Shorter LED life? How much brighter? So far I’m happy with the NiMh AAAs I’m suing (EBL)
dont think that battery is meant to be used, could be wrong tho…
