One of the first pop can flooders, if not the first, the Niwalker MM15 2 x MT-G2, is a two emitter light. I waited until November, 2014 to latch onto it. The review by Selfbuilt mesmerized me for weeks. So many happy memories!
That brings back memories indeed! Still got a couple of these Niwalker MM15s - one from Vinh - and successfully dedomed my first MT-GT leds with this light to give a bit more throw.
I know that this isn’t the light OP is searching for, but this thread seems like the right place for it - the Warsun X608 with 2x Osram P8 and a side-firing COB and inbuilt battery + powerbank function.
16$ with a code from Fin17: Archive topic - Banggood & Fin17
I have this light and I really like it.
It’s not easy to disassemble, but the batteries are really 4Ah, the light colours are all not blueish, the UI is good and the light gets warm after a short amount of time, to the LEDs are all cooled.
Only negatives are the micro-USB port instead of USB-C and that it’s not disassembleable without being destroyed.
Perfect for testing out if that formfactor is suitable for you.
So are you excluding things like the Amutorch with the double-reflector inside an otherwise normal-sized head? Because I think that’s the perfect example of what you said doesn’t really make sense. Lots of wasted space.
