I have one and it’s awesome for features, lumens and size. I would only step down to an AA or AAA if I wanted to go smaller than the SP31 Pro 18350. And now I’m locked into the 31 Pro, Anduril as well.
What is also nice about the sc11 over the short tube Sp31-pro is that it has a pocket clip. You need to source one from Mars to fit the short tube sp31-p from another make/model.
I used the clip from the SC31 Pro that the head and tail cap came from. All you really do is replace the battery tube for $1.49 (Sofirn Store) and buy an 18350 battery. The short tube only has one clip groove, so to change from forward to backward facing, you need to swap the tube 180 degrees. You had to start with a full sized SC31 Pro version anyway since I do not believe they sell an 18350 as a complete light. It is great clipped above or below the bill on a baseball cap. Not enough weight to matter.
It makes a nice, cheap upgrade to the SC31 Pro and you can always go back to the 18650 configuration if you choose.
I’m still thinking to get this or not. As I already have sc31pro which is as good as an 18650 light with lesser runtimes.
I would immediately get one if it was dual 14500 and AA though. with usb C charging for 14500 and option to use AA when you can’t charge. That’s the best option for EDC imo.
Bummer. I was hoping that it was the same as the SC31 Pro. I’m not familiar with the SP35.
Question: When you press and hold the second time from moonlight, does it start the ramp from moonlight level or from the last used normal level? If it starts from moonlight, regardless of the last used normal mode, I could live with that.
I started to order one last night from Sofirn’s website, but they wanted to share information with other entities that I’m not familiar with, so I’ll wait a month or two until it’s available through an American vendor.
If it had a lighted switch or some other way to find it in the dark if drop it when it’s off, it would be nearly ideal for my intended use.
I am a big fan of Sofirn lights (my current EDC is an SC31 Pro 18350, and there’s an SP35 sitting on my nightstand). I’m not all that enamored with this light.
First, it’s long at 73mm. I’m sure a lot of that length comes from the reflector to focus the LH351D to such a nice beam (as shown in the video review). But the Olight Baton 3 (63mm) is 10mm shorter than the SC21, the S1 Mini (54mm) is 9mm shorter than the Baton 3, and the Fenix E16 (51mm) is 3cm shorter than the S1! This thing is longer than the Thrunite T1, which is an 18350 light!
Second, I am doubtful of the runtime/output numbers. The SP10S claims its high mode is 310 lumens for 2 hours 11 minutes (of which that output is inflated) using the same LED. It seems suspicious that this light can maintain 400 lumens for an hour and a half utilizing a battery that has near the same capacity battery as the SP10S. Also take into account that the SP10S claims 80 lumens for nine and a half hours, where the SC21 claims 100 lumens for only four hours. Something seems off…
Third, if this uses the same ramping software as the SP32 and the SP35, then it has the same problem of its ramping curve. Those lights ramp way too linearly, as it takes the same amount of time to increase the same amount of lumens throughout the range. As an example, if it takes the light a quarter of a second to increase 100 lumens, that’s a lot more noticeable when at the bottom of the ramp than at the top (where it’s not easy to distinguish that increase in output). Trying to adjust the lower end becomes much more difficult, where the difference between 5, 20, and 100 lumens is dramatic.
To me, this one seems like a swing and a miss for Sofirn, as well as a missed opportunity to bring a small (around 60mm) 18350 light to market.
