The last remaining AAA I have is the little Ultratac K18 and it's a decent light really. XP-G3 I think (maybe 2), simple UI, side e-switch with lockout, glass lens. I filed off the key ring loop to make it a tail stander but what's there is beefy enough that you'd never have to worry about it wearing through with actual key ring use. If it's still available they had a stainless steel version, too, which would be much more durable. Went through two Lumintop Tool AAA and really never liked it much but that one has a tail clicky, bit larger size than the K18. It's very easy to swap emitters in both of these as well. There are several AA lights now that aren't too much larger and definitely give more punch and/or run time...not sure how many have key ring ends on them, though.
I wouldn't say they're obsolete at all. AA sure has the market, though. There are some AAA models that will also take the 10440 lithium cells. My K18 will but I don't run it with those...just not enough run time with those tiny cells but they do give you an impressive boost in output (I think on that light the lithium is supposed to be 350 lumens or so...briefly). That little Skilhunt looks like a winner. The old Thrunite Ti2 and Ti3 are still around and decent twisties. Seems like Lumintop had another nice AAA that had grooves on the body like the Worm but I don't recall what it was named.
+1 for this. People gripe about it being only single mode, but after EDC-ing it on my keys for a while now, I honestly don’t miss having a low mode. It’s so light and small you forget it’s there. The throw/flood ratio of the beam is also respectable, considering the cell it uses.
100% agree. I love that little light. I have a handful of those Thrunite Ti3’s or whatever they are called. The ones they were giving away for five bucks or something like that. Little three mode twisty. I’ll give ya one if you want it. I think the E3A is a better light though. Just my opinion. If the Reylight Mini Pineapples are still in stock somewhere, those are really nice. Pricey but worth it. Not exactly a keychain light though. The titanium one rides in the pocket very well and I don’t even notice it’s there most of the time. I am test driving a Nitecore Tini 2 on my keyring right now. It’s okay, I’m getting use to it. I like the screen with all the info and the two different lock out modes. I like the Tip 2 as well, easy to take off the keyring and has a magnetic base. Lots of choices. Hope you find the perfect one for you. Drop me a PM with your address if you want one of those Thrunites.
I am still satisfied with the light that has been my EDC for four years now, the AstroLux A01 AAA Nichia 219B High CRI. Pros: small as the dickens, neutral tint, and high-CRI. Cons: Not sure about durability or ruggedness, but mine is still humming along. Claims 100 lumens, but probably more like 70 or 80.
I value CCT near 5000K and high CRI. For EDC, I like tiny.
Which of the new keychain flashlights feature high CRI?
