Keeppower 14430 1050mAh P1443C3 (Black) 2020
Official specifications:
Voltage: 3.70V
Typical capacity: 1050mAh
Minimum Capacity: 1000mAh
Discharge cut-off voltage: 2.50V
Charge voltage: 4.20V +/- 0.05V
Standard charge current: 500mA
Maximum constant discharge current: 2A
This is protected 14430 LiIon batteries, i.e. slightly shorter than AA batteries.
The two cells match fairly well and can deliver the rated 2A current.
Conclusion
These batteries works fine, but the size is not the mainstream types.
Notes and links
The batteries was supplied by Keeppower for review.
Graphical comparison to other LiIon batteries
Table with all tested LiIon batteries
