So, I though I would make a post about the Weltool UV flashlight.
You may wonder the uses for a UV light such as this and so did I! After giving this a try I realised that this could be a very handy tool to have for around the house and also for working on the car. I have used some uv lights before but they have not been very useful as it does not put out enough and is not a very wide beam. This puts out a spectral radiosity of 350uW/cm2 up to 1100uW/cm2 so it is on the professional end of uv lights and is plenty bright enough thanks to the high light transmission tempered glass to put it to good use.
Only down side to this light is it makes you a bit obsessed with cleaning. You don’t realise the dirt on your walls and light switches until you shine this on them. I always feel I have a very clean house but as you can see in some of these pictures it really picks up on every detail left behind. This is a massive help when cleaning up as you can really get a good clean and not miss anything behind. And on a different side this I believe would be helpful for mechanics as it is very very useful for finding leaks. You shine this underneath a car and it will light up and liquid and instantly show you where the problem is. This in my opinion makes this light pretty much essential if you are a mechanic or anyone who likes to work on your own car as it will save you so much time and makes it more simple.
This is also a useful tool for security/Police alike. This light instantly tells you if someone’s identification is legitimate as it will shine up a pattern on the genuine cards. This can also be used to detect counterfeit notes in the same effect.
Another good point is price point, for what you are paying you get an absolute steal. Included is an 18650 batter and charging unit which can be used the charge from a usb powerbank or in any other USB adapter. In the pack you also get some spare o rings for if the ones currently on wear out. This is a complete ready to go kit straight out of the box.
Please find all of my photos below and take the time to notice the comparisons it will really shock you
As you can see all the bearings are very well greased and tough
