All my bicycle lights are running with built-in batteries, except my main ASTROLUX EC01 flashlight. They are running fine and able to last for 4 hrs continuous usage.
The only downside for these cheap LED lights is that they are not good in heavy rain.
Interested.
But I need to know if I have to cycle through the obnoxious blinky modes to get back to high. Does the light have memory, or can I just turn it off and back on to go straight to high?
Edit- just saw on Facebook that the light has no memory, so I should be able to turn it off and back on to go to high. Kind of a pain, but better then having to put up with the obnoxious blinky modes.
I have the light now and I can confirm you can avoid the blinky and off modes. Essentially a double click puts you into high mode with both leds, single click cycles med/low/off, however you can avoid off by double clicking to get back into high. There are no blinky modes with both leds in use.
If you only want to use a single led it’s trickier as you have to cycle all modes, although you can switch from high to low beam (or vice versa) which puts you back into high again, avoiding off and blinky modes. The thing is, you’ll likely be using the lights with both leds running at all times. Both high and low beam have a good anti-glare horizontal cut off, so using a single led seems kind of irrelevant for any purpose.
Edit: after further use, doubleclicking to get back to high mode is a bit problematic. It’s not always easy to doubleclick fast enough while riding and the light momentarily flicks off if you manage to pull it off, which is less than ideal while riding. At this price point the light is still a steal, well made, etc, but UI is disappointing.
