【New Product】XTAR DS1 Dive Light
4 posts / 0 new
xtarflashlight
xtarflashlight's picture
Last seen: 20 hours 48 min ago
So glad to share we released a new dive light – XTAR DS1, special designed for spearfishing.
More info on the website:
https://www.xtar.cc/product/XTAR-DS1-Diving-Flashlight-170.html
Main features:
• Max output 1000lm, runtime 2.5hrs
• Magnetic slide switch, with a spare one to replace
• 7-degree spot beam angle and 280m beam throw
• Cree XP-L2 LED & CCT 5500-6500K
• Compact size ( 15.6cm long)
• Aluminum alloy AL6063 housing
• Waterproof rating 100m underwater
• Multipile protections for diving safety
How do you think of it? Comment freely.
Lightbringer
Lightbringer's picture
Last seen: 5 hours 20 min ago
What’s the parasitic drain?
My DV-S9 has a similar slider, and to linearly sense the magnet over almost a half-inch of travel, it needs to run its sensor at about 10mA, which drains a full 5000mAH 26650 in about 20 days.
Great little light, but you can’t keep it sitting unattended for very long.
rogue2020
Last seen: 4 months 6 hours ago
Hi,
That's an interesting flashlight, but does it have a Thermal or Temperature Reduction function? e.g. The flashlight's lumens would be automatically lowered when a certain temperature has been reached.
Also, it would be nice if you could have a switch that is like the Sofirn SD05 for some of us who are used to it.
Thanks!
xtarflashlight
Thanks for your kind comment! Our dive lights have smart temperature control. When temperature within rises up to a high level, it will automatically reduce the brightness, to protect the light from being damaged by high temperature, also ensure the light will work fine underwater for a long time.
