How a rear switch then somehow comes into play with a pinky IDK.
—- i think he meant using CopCarry with a sideswitch, then your pinky is near the head of the light, where the switch is
wle
wle
Why would a cop put his thumb behind a tail cap when there isn’t a switch there to begin with?
copcarry w tail switch: thumb on switch
copcarry with side switch: pinky on switch (awkward)
and vice versa
“Why would a cop put his thumb behind a tail cap when there isn’t a switch there to begin with?”
—maybe to hold it better in case he had to bean a Bad Guy with the light (ie not for the switch)
ha
what i do is ‘wrong’
i have a tail switch light
but i use it in several UnCopCarry modes
usually i just turn it on and adjust mode, then go to Opposite CopCarry mode, where a side switch would be better, but i don;t have a side switch
or cigar mode, between index and middle finger
Seems I intended to post a second reply but didn’t get around to it, or the data vampires ate it mid-send. Oh well.
Using the pinky to press the switch is not very smart. The pinky is made for scratching ears, flagging good tea and pressing Ctrl on the keyboard, not for applying force Try using your ring finger next time, it’s much easier.
Like a boss
We seem to be going round in circles a bit here. We could do with some diagrams and shared terminology.
From what I can tell much of this depends on the preference to hold a light either at waist hight or head hight.
How’s this for naming? What other ones are there?
I like to hold mine like a lightsaber and pretend I’m a jedi so sideswitch all the way for me!
Maybe we should get more creative in the naming! :smiling_imp:
Those are all good ones. But let’s just keep it simple when it comes to Grip Terminology.
*4. Unorthodox
*5. Catholic
I just hold them in my . If I ever get crippled things may change…then I’ll come back to this thread for some inspiration.
I am right handed, but being ambidextrous I hold with my left and us my second finger to run the switch. I find that my left hand has better dexterity for rapid clicks on most switches. I also carry on my left side as knives are clipped into my right change pocket or normal pocket. Tailswitch lights are also easier to operate with my left hand. Once on, I tend to wrap the whole hand around the light, either left or right. I think this explains my love of larger tube lights 21700 and 26650 format.
‘mic style’
I hold my side switch lights the proper way. Any other way is improper.
I used to carry a rechargeable Maglite for work when I was a teenager (long ago). I rested the main weight of the body on my shoulder, hand partially around the base of the head, with the side switch at the index, middle finger, or ring finger. One mode, so the only time you needed to press the button was for on or off. The head didn’t get that hot with the limited power of the time.
It was very comfortable and intuitive. It felt a little like carrying a short baseball bat rested on your shoulder. At the time, there wasn’t the whole “on-off… on-off… on-off” (momentary) technique taught today (that I’m aware of) so even less need for excessive button usage. The newer Streamlight Protac HL5-X works well with this technique, although it’s too short to rest the weight of the flashlight body on the shoulder.
IMO, with the smaller lights of the last 20 years, the tail switch just seems more ergonomic with the higher hold. Heat accumulation of today’s higher power flashlights is also significant around the head and not so touch friendly. Additionally, with the higher lumen flashlights of today, more lumen can be designed into the spill, which can increase the shadow casting when compared to the tight spot of the old, throwy, incandescent, Maglite style lights/reflectors.
IMO, some of the reasons for the higher “tactical” hold that don’t include defensive/offensive use scenarios might include efficiency of movement (since it is held closer to the body and related pivot), easier to find and actuate the tailswitch in the dark or with gloves, and for shining over things that are above waist height, such as a couch, railing, vehicle, bed of a truck, bushes, etc.
Generally speaking, with current flashlights I hold the flashlight low (handshake?) if I need to shine it for long periods of time, and higher (tactical and sometimes cigar) for shorter, more immediate tasks (if a tailswitch is available). With the old 4D sized Maglite, since the weight was mostly resting on your shoulder one could keep the high hold for long periods of time, even though it was a large and relatively heavy light.
Handshake Grip
Tactical Grip
Cigar Grip
Only thing about calling it “microphone grip” is that the business end of the light is exactly opposite of the business end of the microphone.
This will possibly confuse many.
