✅【 GROUP BUY 】Convoy 3X21A 3*SFT40/SST40 6800LM 3*21700 Flashlight ✺
41 posts / 0 new
Fin17
Fin17's picture
Last seen: 8 hours 42 min ago
✺ CONVOY 3X21A ✺
3xSST40/SFT40 Flashlight
Group buy price - $xx.xx
Specifications:
Brand
CONVOY
Product name
Flashlight
Material
Aluminum alloy
Low voltage warning
Automatic power off
Reverse polarity protection
None,The positive side of the battery should be facing the head
Lens Type
Ar-coated glass lens
Reflector
Smooth
Charging
TYPE-C charging interface (charging current 3A)
Switch position
Side button in the head
Mode memory
Yes
Tail stand
Yes
Battery included or not
Not included
Battery type required
3*21700 batteries (unprotected)
Luminous flux
Maximum 6800LM(SST40)/5400LM(SFT40)
Illumination
Maximum 265KCD(SFT40)/142.5KCD(SST40)
Range
Maximum 1029m(SFT40)/755m(SST40)
Tc
6500K/5000K
Output current
17.8A (SFT40)/16A(SST40)
Head diameter
69mm
Battery tube diameter
51.8mm
Flashlight length
158.4mm
Product weight
569g
Weight with box
706g
Packing size
183 * 98.5 * 78.9mm
 If you are interested notify in this thread (not in PM)
My thread:
 BangGood.com Deals
Edited by: Fin17 on 07/06/2021 - 15:26
Fin17
Fin17's picture
reserved
heater
heater's picture
Last seen: 1 hour 40 min ago
Interested in SFT40 version, if it is the 3×21A like in your picture.
TermsakC
TermsakC's picture
Last seen: 1 hour 6 min ago
I am considering buying either this Convoy 3 × 21A or Sofirn Q8 Pro.
The 7.7 Sale in Singapore is approaching. The price of Q8 Pro will come down to just around US$60 (without battery).
On paper, the Q8 Pro claims to generate up to 11,000 lumens, whereas Convoy 3 × 21A can produce only about 6,000.
Can anyone share insights in comparing these two lights? What are their major pros and cons?
ArtieT59
ArtieT59's picture
Last seen: 4 hours 52 min ago
TermsakC wrote:
I am considering buying either this Convoy 3 x 21A or Sofirn Q8 Pro. The 7.7 Sale in Singapore is approaching. The price of Q8 Pro will come down to just around US$60 (without battery). On paper, the Q8 Pro claims to generate up to 11,000 lumens, whereas Convoy 3 x 21A can produce only about 6,000. Can anyone share insights in comparing these two lights? What are their major pros and cons?
Convoy 3x21a will have much more throw. Much more. So you will need to decide do you want twice as many lumens (bright) or twice as much throw (distance), may not be twice as much throw but it will be noticeable to the eye.
Check out some of my new lights (picture heavy) and quick first impressions of them here: https://budgetlightforum.com/node/77180
ArtieT59
ArtieT59's picture
Interested!
this will probably be the one new Convoy I buy right away. I have enough sbt90 lights, and this will save me from having to modify the ft02s with sft40. Can't wait for this light.
I just wish the head was bigger like 80mm Smile
AlexGT
AlexGT's picture
Last seen: 1 hour 49 min ago
Interested, Anyone have a size comparison photo next to a BLF Q8?
What UI does it use?
TermsakC
TermsakC's picture
Thanks Artiet59 for your insight.
Now I am leaning towards buying this Convoy light. I have a Sofirn Q8, and so in no urgent need for the Q8 Pro.
BTW, can we expect more “discount” offers during the upcoming 4th of July holiday?
I am outside of the USA; therefore, I don’t know the shopping business strategy or whether such sale event is going to happen at all during such a major American holiday.
Here in Singapore, sale is happening every month. Last month it was the 6.6 Sale. Now the 7.7 Sale is coming. And next month, it will be an even bigger monthly sale of 8.8 which will coincide with Singapore’s National Day on 9 August.
stephenk
stephenk's picture
Last seen: 6 hours 15 min ago
I would be interested to compare the beam angle between this and the Q8 Pro.
dolbysys
Last seen: 1 day 22 hours ago
maxchaos92
Last seen: 7 hours 54 min ago
interested in sft40 version Silly
Unloco
Unloco's picture
Last seen: 1 day 4 hours ago
Interested.
heater
heater's picture
SFT40 order placed. Thank you Smile
khas
Last seen: 1 week 3 days ago
Interested in SFT40 version.
Thanks
Nickryan915
Interested in sft model.
khas
Order placed for a 3×21A SFT40 version, thank you for the coupon.
AlexGT
AlexGT's picture
What is a good 21700 5000mah battery for it?
Molicel NPE INR-21700-M50A 15A 5000MAH FLAT TOP
or
VAPCELL G50 21700 15A FLAT TOP 5000MAH
Any other high capacity and high discharge cells you would recommend?
Thanks!
AlexGT
ArtieT59
ArtieT59's picture
AlexGT wrote:
What is a good 21700 5000mah battery for it? "Molicel NPE INR-21700-M50A 15A 5000MAH FLAT TOP ":https://liionwholesale.com/products/molicel-npe-inr-21700-m50a-15a-5000m... or "VAPCELL G50 21700 15A FLAT TOP 5000MAH ":https://liionwholesale.com/products/vapcell-g50-21700-15a-flat-top-5000m... Any other high capacity and high discharge cells you would recommend? Thanks! AlexGT
I would think this would be good as well (US customers)
https://www.18650batterystore.com/collections/21700-batteries/products/e...
AlexGT
AlexGT's picture
ArtieT59 wrote:
AlexGT wrote:
What is a good 21700 5000mah battery for it? Molicel NPE INR-21700-M50A 15A 5000MAH FLAT TOP or VAPCELL G50 21700 15A FLAT TOP 5000MAH Any other high capacity and high discharge cells you would recommend? Thanks! AlexGT
Thanks for the suggestion, will look into it. Smile
I am wondering does this light accept button top cells or does it have to be flat top with the provided adaptor?
delete
Last seen: 7 hours 8 min ago
interested.
thank freeme for my request.
peteybaby
peteybaby's picture
Last seen: 3 days 8 hours ago
interested
Duke
Last seen: 4 days 1 hour ago
Thanks
zoulas
zoulas's picture
Last seen: 2 hours 43 min ago
Is this the same host as 4×18650 sbt90
2? Looks the same.
Fedtro
Last seen: 38 min 22 sec ago
Interested
ill-luminati
Last seen: 8 hours 19 min ago
interested SFT40
zoulas
zoulas's picture
Is this the same physical size as the 4×18 SBT90.2?
Fin17
Fin17's picture
zoulas:
4X18A (3X21A)
Head diameter 69mm (69mm)
Battery tube diameter 50mm (51.8mm)
Flashlight length 153mm (158.4mm)
Product weight 458g (569g)
zoulas
zoulas's picture
Is the SFT40 available, seems sold out.
zoulas
zoulas's picture
Question:
Why the big attraction to the SFT40 when it only comes in cool white?
vit55
Last seen: 11 hours 16 min ago
Interested in SFT40
Fin17
Fin17's picture
The offer is active
