Rusty_Joe
(Rusty Joe)
April 1, 2012, 3:53am
69
p0708:
Just a word of caution though rusty Joe,
better do a throughout check on your King from light mall, coz I got one with 1 of the 3 Led not working. Had to pry out the driver board, remove the reflector and test the led with direct drive. I have changed a spare 16mm XML in since, and that company as for proof. But I forgot to take pics before I did the repair. Now its my words against theirs and I dun think I will get anything out of this episode.
Phil
Thanks. Well, I hope it's not defective or at least they better be an honest company!
Unknown
(Unknown)
May 6, 2012, 7:09pm
70
I'm waiting both. I'll report if any differences.
benckie
(benckie)
May 27, 2012, 3:27am
72
A new king in black 5 x T6 with lanyard and handle ?
https://budgetlightforum.com/t/-/8893
theo_mich
(theo_mich)
May 27, 2012, 7:39am
73
I received both, and they are exactly the same
_the
(_the_)
May 27, 2012, 8:14am
74
Nice try. :)
I... must... resist... ;)
Ps. Sorry about the missing pics in my reviews. My photo host upgraded to new version and the old links don't work for some reason. Please be patient. I'm working on it..
FX-32
(FX-32)
June 2, 2012, 2:25am
75
Hi _the_, could you do this test if you have time and want to?
Because visually I don't note difference when using with ONE battery than with four, so I think it would be interesting to know if with lower voltage it stills with same output.
Thanks!
FX-32:
I have a question to somebody having this flashlight, and a lumen meter, or ceiling bounce meter:
- Does lumens change when standby battery voltage isn't 4.20V?
I mean, If I charge them to 4.00, or 3.80, or maybe less, at which point it starts decreasing output?
Manny
(Manny)
June 5, 2012, 2:08am
76
Any Holster for the SkyRay King ? I just ordered a Nitecore Tiny TM11 holster in the US for $10.00 and $2.00 shipping. Hope it fits……
I find it weird that this light is brighter than the NW DRY on turbo when the turbo driver already sends 4 amps to every led.
From where I can buy this for cheapest ?
Anyone know a way to buy body only ? (without emitters)
Manny
(Manny)
July 8, 2012, 11:32pm
79
My King came to real life with Orbtronic cells period ! This torch requires real cells to shine ……
attitude
(attitude)
July 9, 2012, 2:50am
80
Would flat cells be ok for this light ? i got 4x panasonics NCR18650s flat top
Manny
(Manny)
July 9, 2012, 6:50am
81
If they look like this yes……
attitude
(attitude)
July 9, 2012, 7:19am
82
no they look liek grey ones. flat tops
CM2010
(CM2010)
July 19, 2012, 9:55am
83
Just about to order this light, what would be the best batteries to use and can i use either button top or flat top?
Would these be ok?
UK supplier of LED Torches from Fenix, Nitecore, Zebralight, Eagletac, Olight, Klarus plus Maxpedition Gear. Wide range of Li-ion batteries and Chargers. Buy with same day dispatch from the UK.
Thanks for joining, CM2010. Welcome to BLF!
Manny
(Manny)
July 19, 2012, 1:34pm
85
These are flat tops. You need Orbtronic or AW button tops. The best for the King…… Of any light…. I have seen a lot of batteries come and go, damaged, burnt, self destruct, but the Orbtronics keep on ticking and after 10 charges get stronger !
FX-32
(FX-32)
July 19, 2012, 1:38pm
86
Manny:
Have you tried the king with AWs? They are LMR (“IMR”) so I would like to know if the king supports that.
Every battery capable of discharge at 5A without problem, would be great for the king, like the Orbtonic, Trustfire 3000, etc.
DarkSide
(DarkSide)
July 19, 2012, 2:00pm
87
FX-32:
Manny:
II would recommend flat top AW’s. With any light that requires direct PCB to battery contact, button tops will damage the surface unlike a spring. You can use button top spacers. AW’s are widely known for there 1600mah red label
cells they made a few years ago, discharge 9-10amps. Oh, and Black Label 32650’s and 26500 as well…
Manny
(Manny)
July 19, 2012, 2:05pm
88
This is the best image of what the top of the battery should look like ! To fit the King……
Diese Website steht zum Verkauf! supertmanufacturing.com ist die beste Quelle für alle Informationen die Sie suchen. Von allgemeinen Themen bis hin zu speziellen Sachverhalten, finden Sie auf supertmanufacturing.com alles. Wir hoffen, dass Sie hier...
