Interested!
Interested in a couple.
I’m interested, too.
Interested.
Interested.
Interested, will buy one.
New and also interested. Ordered a few Sofirn’s already.
Saw this brand new listing pop up on sofirns local shopee store (shopee is a large e-commerce platform in southeast Asia).
Could just be a typo - but maybe it’s a sign that the new anduril version is about to drop? A man can hope…
What the heck… interested.
Interested
Wonder if that would work on my SC31 Pro…
It appears to be made for AA-sized lights, so it would probably be a tight squeeze at best.
Interested!
Interested.
Also saw the reference to the “SP10 v3.0” even though this model doesn’t seem to be available yet.
I wonder if the SP10 v3.0 is an updated model of the SP10B / SP10v2.0 (both of which use XP-G2 LED) or maybe it will use a different LED (SP10S use LH351D).
I also noted for sale in Sofirn’s site are “pocket clips for SP35 / SP35T” (SP35T model doesn’t seem to be available yet, I wonder what is updated for the “T” over the regular SP35)
SP35T will introduce a tailclicky next to the side switch.
VERY interested. Sign me up for at least one.
Interested in something other than Black
Thanks
OS
Thanks for the info (although a bit off-topic for this message thread).
So basically the SP35T will be similar to a 21700 version of the SP31v2.0 in terms of having a tail+side switch…
(I wonder if they’ll consider using an SFT40 LED in place of the SST40…) For a tactical EDC thrower…
+++ Great news +++
Sofirn is now able to source the new AVR-1 MCUs, i.e. 1616-MNR. I am in close communication with Barry (Sofirn), Tom E and gchart to get this project into its final phase. Fingers crossed that waiting will soon be over...
UI-wise following specs are planned:
- Andúril 2 in its latest revision
- USE_2C_MAX_TURBO command in the Advanced UI, i.e. similar to Sofirn SP36/Q8 (Pro) configuration, see latest UI diagram for reference below.
- Direct access to toggle ramp mode (stepped/smooth) from Simple UI via 3C
- Default Ceiling Simple UI: 150/150 (I think this should be fine for a tiny light like this)
- Default Ceiling Advanced UI: 150/150 (I think this should be fine for a tiny light like this)
- Default Ramp Mode: Stepped Ramping with 4 stepping increments (to reflect something like Low-Med-High-Turbo)
Hardware-wise I am still collating some more information. I suppose Sofirn will be using Samsung LH351D 5000K 90CRI. Maybe they can also offer a (limited) run with 2700K/4000K, too. A green-coated lens would definitely help to reduce any greenish tintshift in terms of chromaticity and lower the Duv closer to or even below the BBL.
