【Add a 18350 Tube】Wurkkos HD15/HD15R USB-C Dual Emitters Rechargeable Headlamp(Update)
Nice!
Has your order already been shipped?
I hope so... haven’t received notification though
eager...
Yup. I like this light, but I already have a pile of lights that need the cool white emitters replaced and I’m getting tired of swapping LEDs. I’ll order one when it has neutral/warm LEDs.
ugh. I wish this used Carlco optics so I could customize the beam.
I really thought Emisar would have made a light like this by now… (essentially 21700 D4)
short tube 20350 available for TS21, HD20 now, compatbile 16340, 18350,
Don’t miss the 20350 battery tube, we are not sure how many pcs we will make.
What would you like to know?
5000K and 4000K available on sofirn aliexpress store.
standard wurkkos rubber switch, and one way deep carry clip (clip is not that important).
The switch is deal breaker for Me, because I already have lumintop fw21 on SST-20 4000K (if I didn't have it, I would buy).
TS21 is the best USB C high CRI "budget" tri lens flashlight I can see so far :THUMBS-UP: , almost perfect, but that switch. It's not bad, but why use different switch.
Nice! There are a few things I’d like to know before buying one though, can somebody who already has one verify these for me please?
  • Is the magnet easy to remove? I don’t really want a light with a magnet in my pocket…
  • What is the driver? I suppose PWM/FET instead of constant current buck driver because it’s not mentioned anywhere?
  • Are there pads available to flash another version of Anduril?
  • Does the light charge with USB-C -> USB-C cables?
Thanks!
I’ll wait for the driver confirmation first.
Received my review example
  • Define your opinion of easy, i think it should be doable
  • it has PWM
  • there are NO flashing pads on the driver
  • yes, it is USB C - C compatible
It does not say which emitters or tint it is, there wasn’t even a manual inside the box.
The tint looks a bit warmer than my 6500 K TS30, it shows a greenish hue on lower modes
Too bad. Initially they said buck driver and with flashing pads. :frowning:
Thanks for the answers!
Yeah that’s kinda disappointing. I guess I’ll stick to my Sofirn IF25A for now…
So, Wurkkos, you lied about the driver.
See the post above where the test showed PWM and you said initially it is buck driver.
Do you know what buck driver is?
I was gonna say Adam Driver’s and Minnie Driver’s cousin, but… :stuck_out_tongue:
Now you can order 4000K, or 5000K on our website.
Do you mean constant current?
Hi Terry, I’m from Malaysia and usually order from your official Lazada online store. Will you be offering these tints on your other official online stores soon?
Yes, you can order tomorrow from Lazada.
