SFT40 order placed. Thank you
Interested in SFT40 version.
Thanks
Interested in sft model.
Order placed for a 3X21A SFT40 version, thank you for the coupon.
What is a good 21700 5000mah battery for it?
Molicel NPE INR-21700-M50A 15A 5000MAH FLAT TOP
or
VAPCELL G50 21700 15A FLAT TOP 5000MAH
Any other high capacity and high discharge cells you would recommend?
Thanks!
AlexGT
I would think this would be good as well (US customers)
Thanks for the suggestion, will look into it.
I am wondering does this light accept button top cells or does it have to be flat top with the provided adaptor?
interested.
thank freeme for my request.
interested
Thanks
Is this the same host as 4x18650 sbt90
2? Looks the same.
Interested
interested SFT40
Is this the same physical size as the 4x18 SBT90.2?
4X18A (3X21A)
Head diameter 69mm (69mm)
Battery tube diameter 50mm (51.8mm)
Flashlight length 153mm (158.4mm)
Product weight 458g (569g)
Is the SFT40 available, seems sold out.
Question:
Why the big attraction to the SFT40 when it only comes in cool white?
Interested in SFT40
The offer is active
Thx Fin17, I purchased the SFT40 version and received the light.
I did a run into an issue though:
The early run of these lights had an adapter plate issue for flat tops, it’s documented by simon on aliexpress for the 3X21A
I’m currently working with BG to resolve this issue and hoping to get a replacement adapter. I had to make a video for proof, so might as well share it here. They have been responsive.
https://youtu.be/kSw5mKgkO64 plate defect video
The light does run on 1-3 batteries, but I only recommend this for testing.
I do like the light, it has a very nice finish, and seems to have good throw. I can’t wait to test this light when it’s fully functional.
