Don’t miss the 20350 battery tube, we are not sure how many pcs we will make.
What would you like to know?
5000K and 4000K available on sofirn aliexpress store.
standard wurkkos rubber switch, and one way deep carry clip (clip is not that important).
The switch is deal breaker for Me, because I already have lumintop fw21 on SST-20 4000K (if I didn't have it, I would buy).
TS21 is the best USB C high CRI "budget" tri lens flashlight I can see so far :THUMBS-UP: , almost perfect, but that switch. It's not bad, but why use different switch.
Fescron: Wurkkos Terry:6500K for this batch.
Aah that’s too bad but I get it, guess I’ll order one later
Nice! There are a few things I’d like to know before buying one though, can somebody who already has one verify these for me please?
- Is the magnet easy to remove? I don’t really want a light with a magnet in my pocket…
- What is the driver? I suppose PWM/FET instead of constant current buck driver because it’s not mentioned anywhere?
- Are there pads available to flash another version of Anduril?
- Does the light charge with USB-C -> USB-C cables?
Thanks!
I’ll wait for the driver confirmation first.
kokosnh: Fescron: Wurkkos Terry:6500K for this batch.
5000K and 4000K available on sofirn aliexpress store.Nice! There are a few things I’d like to know before buying one though, can somebody who already has one verify these for me please?
Thanks!
Received my review example
- Define your opinion of easy, i think it should be doable
- it has PWM
- there are NO flashing pads on the driver
- yes, it is USB C - C compatible
It does not say which emitters or tint it is, there wasn’t even a manual inside the box.
The tint looks a bit warmer than my 6500 K TS30, it shows a greenish hue on lower modes
- it has PWM
Too bad. Initially they said buck driver and with flashing pads.
Fescron: kokosnh: Fescron: Wurkkos Terry:6500K for this batch.
Thanks!
- it has PWM
Thanks for the answers!
Yokiamy:
- it has PWM
Yeah that’s kinda disappointing. I guess I’ll stick to my Sofirn IF25A for now…
lfb:There is any estimate of when reviewers will start to receive samples? I’m just curious to see it.
So, Wurkkos, you lied about the driver.
See the post above where the test showed PWM and you said initially it is buck driver.
Do you know what buck driver is?
I was gonna say Adam Driver’s and Minnie Driver’s cousin, but…
Yup. I like this light, but I already have a pile of lights that need the cool white emitters replaced and I’m getting tired of swapping LEDs. I’ll order one when it has neutral/warm LEDs.
Now you can order 4000K, or 5000K on our website.
Wurkkos Terry: lfb:There is any estimate of when reviewers will start to receive samples? I’m just curious to see it.
Do you mean constant current?
TexasToasted: Fescron: Wurkkos Terry:6500K for this batch.
Hi Terry, I’m from Malaysia and usually order from your official Lazada online store. Will you be offering these tints on your other official online stores soon?
Wurkkos Terry: TexasToasted: Fescron: Wurkkos Terry:6500K for this batch.
Yes, you can order tomorrow from Lazada.
darosk: Wurkkos Terry: TexasToasted: Fescron: Wurkkos Terry:6500K for this batch.
What great service! Thanks Terry
id30209: Wurkkos Terry: lfb:There is any estimate of when reviewers will start to receive samples? I’m just curious to see it.
Yes.
So what driver you have in it?
I’ve got my sample. Moddable 100%.
First i was surprised seeing thin white sticker over the MCPCB but when i removed it i saw the green light from the switch so it’s sole purpose is to hide it.
Now i need to swap emitters to some nice high cri.
Ooh nice thanks for the pictures! Did you dig any deeper? So the driver is visible?
Driver is visible from the back side of the head and it looks like it’s glued. Applying some heat to soften the glue will help you removing it but i won’t do that now. Later maybe.
