Define your opinion of easy, i think it should be doable
it has PWM
there are NO flashing pads on the driver
yes, it is USB C - C compatible
It does not say which emitters or tint it is, there wasn’t even a manual inside the box.
The tint looks a bit warmer than my 6500 K TS30, it shows a greenish hue on lower modes
Hi Terry, I’m from Malaysia and usually order from your official Lazada online store. Will you be offering these tints on your other official online stores soon?
First i was surprised seeing thin white sticker over the MCPCB but when i removed it i saw the green light from the switch so it’s sole purpose is to hide it.
Now i need to swap emitters to some nice high cri.
Driver is visible from the back side of the head and it looks like it’s glued. Applying some heat to soften the glue will help you removing it but i won’t do that now. Later maybe.
