I’ll wait for the driver confirmation first.
Received my review example
- Define your opinion of easy, i think it should be doable
- it has PWM
- there are NO flashing pads on the driver
- yes, it is USB C - C compatible
It does not say which emitters or tint it is, there wasn’t even a manual inside the box.
The tint looks a bit warmer than my 6500 K TS30, it shows a greenish hue on lower modes
- it has PWM
Too bad. Initially they said buck driver and with flashing pads.
Fescron: kokosnh: Fescron: Wurkkos Terry:6500K for this batch.
Aah that’s too bad but I get it, guess I’ll order one later
5000K and 4000K available on sofirn aliexpress store.Nice! There are a few things I’d like to know before buying one though, can somebody who already has one verify these for me please?
- Is the magnet easy to remove? I don’t really want a light with a magnet in my pocket…
- What is the driver? I suppose PWM/FET instead of constant current buck driver because it’s not mentioned anywhere?
- Are there pads available to flash another version of Anduril?
- Does the light charge with USB-C -> USB-C cables?
Thanks!
- it has PWM
Thanks for the answers!
Yokiamy:
- it has PWM
Yeah that’s kinda disappointing. I guess I’ll stick to my Sofirn IF25A for now…
lfb:There is any estimate of when reviewers will start to receive samples? I’m just curious to see it.
What would you like to know?
So, Wurkkos, you lied about the driver.
See the post above where the test showed PWM and you said initially it is buck driver.
Do you know what buck driver is?
I was gonna say Adam Driver’s and Minnie Driver’s cousin, but…
Yup. I like this light, but I already have a pile of lights that need the cool white emitters replaced and I’m getting tired of swapping LEDs. I’ll order one when it has neutral/warm LEDs.
Now you can order 4000K, or 5000K on our website.
Wurkkos Terry: lfb:There is any estimate of when reviewers will start to receive samples? I’m just curious to see it.
Do you mean constant current?
TexasToasted: Fescron: Wurkkos Terry:6500K for this batch.
Hi Terry, I’m from Malaysia and usually order from your official Lazada online store. Will you be offering these tints on your other official online stores soon?
Wurkkos Terry: TexasToasted: Fescron: Wurkkos Terry:6500K for this batch.
Yes, you can order tomorrow from Lazada.
darosk: Wurkkos Terry: TexasToasted: Fescron: Wurkkos Terry:6500K for this batch.
What great service! Thanks Terry
id30209: Wurkkos Terry: lfb:There is any estimate of when reviewers will start to receive samples? I’m just curious to see it.
Yes.
So what driver you have in it?
I’ve got my sample. Moddable 100%.
First i was surprised seeing thin white sticker over the MCPCB but when i removed it i saw the green light from the switch so it’s sole purpose is to hide it.
Now i need to swap emitters to some nice high cri.
Ooh nice thanks for the pictures! Did you dig any deeper? So the driver is visible?
Driver is visible from the back side of the head and it looks like it’s glued. Applying some heat to soften the glue will help you removing it but i won’t do that now. Later maybe.
Can you post image to see back of the driver. It interesting to view is there any pins for flashing firmware.
Unfortunately, there are no flashing pads on the driver board.
Thanks :+1:
No pads...
