then EDC18 + 18350 tube + Dual Position Deep Pocket Clip (short + magnet, and wide beam, lots of LED to choose, but no USB C charging), make shure that you order the bunny logo switch one.
there was a EDC18 batch with dark switch, because of that bunny energizer thing.
Ti is sexy and light, but I want better heat dissipation than Ti offers. Aluminum is preferred.
Some variant of that light is still under consideration.
copper head :+1:
or maybe buy the aluminiun version and request the lighted switch?
ther is a copper EDC18 + copper 18350 tube, looks good. Well I even have copper EDC18, but no copper 18350 tube. It's heavy, not suitable for EDC, and no magnet.
Lumintop EDC18 (aluminum), w/SST20 4000K, 95+HCRI, and optional 18350 short tube.
Very happy with this as an EDC. I will say that I do appreciate the EDC18’s Anduril-1 UI. Customizable to turn on and ramp from very low moonlight. The SST-20 4000K, 95+ HCRI, slightly floody, is also very nice!
You will also need to purchase a two-way clip to replace the original, and source the lit “bunny version”.
LightObsession:I want better heat dissipation
copper head :+1:
That’s just flat out handsome.
LightObsession:Does it have a lighted switch option?
the Ti version yes,
choice of 6 different switch backlight colors
This is old info . You can ask for lighted switch with the al version .
That looks like a possibility.
I like this, they have a raw aluminum with the short tube and CW…very nice
What I don’t like is that the UI doesn’t allow direct access to the low end of the ramp from moonlight or from off, unless low was the last used level before switching off.
==but anduril does that, press and hold from off, goes directly to lowest ramp configuration setting
you have to hold about half a second, longer than just a ‘click’
what am i missing?
There’s plenty of options that have short tubes available - D4v2, KR4, FW3A, etc…
what am i missing?
He may have overlooked manual memory, which can be freely adjusted.
wle:What I don’t like is that the UI doesn’t allow direct access to the low end of the ramp from moonlight or from off, unless low was the last used level before switching off.
what am i missing?
but it does not depend on memory, mine will always enter at the lowest level set, regardless of the last mode, if i just press and hold from off
what am i missing?
the OP bought a light without Anduril
now he has to buy another light… LOL!
While not a side switch, I’ve got a shorty body on my FW1A Pro.
Not Anduril but I’ve got a shorty body on my D4 too.
Both are super compact.
what am i missing?
The Thrunite T1 doesn’t have Anduril - that’s the light that I was referring to in the OP.
I like everything about it, except the UI and lack of lighted switch.
Smallest Anduril light I own - 66mm / 2.75” length.
Deep carry clip from an FW1A.
