Identification of UV LED
8 posts / 0 new
nutarvihelg
Last seen: 1 year 6 months ago
Hi!
I am trying to repair a UV detector module for a chromatographic device and wonder if anyone can help me identify the UV LED lamp and PCB on the linked images?
Thanks a lot!
https://imgur.com/a/KrnLi5C
moderator007
moderator007's picture
Last seen: 1 week 5 days ago
I didn’t have a clue what this led was. I really can’t tell too much by the pic, no pic of height or a unsoldered pic would be helpful.
I did some searching and about the only thing I come up with was this.
https://www.thorlabs.com/thorproduct.cfm?partnumber=LED255J
This may not be the right wavelength but hopefully it will help in getting the search words right.
A UV led with a ball lens. Wink
nutarvihelg
moderator007 wrote:
I didn’t have a clue what this led was. I really can’t tell too much by the pic, no pic of height or a unsoldered pic would be helpful. I did some searching and about the only thing I come up with was this. https://www.thorlabs.com/thorproduct.cfm?partnumber=LED255J This may not be the right wavelength but hopefully it will help in getting the search words right. A UV led with a ball lens. Wink
Thanks a lot! I think this might be exactly what I am looking for! Smile
D10ten
D10ten's picture
Hi, just got my WK30 and I don’t know what this UV LED is.
20210703-125457
It doesn’t look like a LG UV LED that others have gotten.
ggf31416
Last seen: 3 days 11 hours ago
It looks like an SST-10 UV but the color should be white, not golden, and the third wire shouldn’t be there so I’m not sure. Can you estimate its dimensions?
Edit: It looks like the golden layer is above the LED and one corner peeled off showing white underneath. Maybe they ran out of LG LEDs and attempted to disguise an SST-10 with golden paint even if it sounds bizarre.
Edit 2: No, it’s golden even inside the dome, the golden color was applied by the LED manufacturer, not by Wurkkos. Maybe it’s a new revision of SST-10 UV.
Serlite
Last seen: 4 hours 51 min ago
If this is the SST-10 UV, then Sofirn has been mislabelling their SP31 UV from the get-go as well.
It’s listed as having an LG UV LED, but the one I got (and the review samples, based on photos online) have this emitter.
D10ten
D10ten's picture
It looks like a standard 3.45mm LED. But, it looks ever so slightly bigger than the Red XP-E2 and LH351D.
20210703-222759
It is golden inside and golden on the raised edge. It appears to have a flat glass on top instead of a dome.
Edit: I think I found the LED. But, there is not much information on it.
UV-LED
Edit 2: Nevermind, I see that the white substrate looks different…
ggf31416
Yes, it looks like the same LED as in the SP31A, but the identification of that LED isn’t clear either.
It’s similar to the one from the 395nm version but the dot pattern is parallel to the border, not diagonal, so it’s a different LED.
Edit: It may be an unlisted 3535 LG LED based on the “Gen. 4 series” Bare Chip listed on https://www.irtronix.com/uva at the bottom, the ones reviewed by djozz are apparently based on the “Gen. 3 series” chip.
The similitude with the SST-10 makes me wonder who actually manufactures what.
