Thanks for the SFT40 beamshots, the more i see of this LED the more i like it.
As for your rosiness issue, i can only guess that there is an issue with color reproduction in the camera in that the camera is reducing the specific band of colour that would ordinarily mask the rose in the SST20, and that there is enough difference in the colours produced by the SST20 and XP-L HI for the XP-L to not be affected as much.
It would have to quite a specific and unusual set of circumstances for this to happen though which makes me think this is not the right explanation but i can’t perceive another one at the moment.
Have you got another camera you can try? Or does this happen with multiple cameras?
EDIT - Another thought, the hotspots are irrelevant here because they are blown out so the rosiness is reversed in the spill only. Is the XP-Ls spill that you can see in the picture rosier in RL than the SST20s spill?
Unfortunately i do not, just an ipad, which i will try, but that camera is shyit!
I should've been more clear - i am only talking about the spill
Yes, in RL the xpl-hi's spill is MUCH ROSIER than the sst20. in RL the xpl-hi's spill is NOT yellow at all, and the sst20's spill is NOT rosy at all. pretty much, they look the EXACT OPPOSITE in RL versus this picture.
Another thing i find interesting - the SST40 that looked rosy and warm in the picture a few posts back (Specifically see Post #9), looks yellow and not rosy in this post (#17)
*I only capitalize to illustrate the emphasis of the words, i'm not angry. well I'm not angry at you, just my picture taking abilities
SST20 4000K (FA4) in my E07X is not yellow. Its rosy compared to SST20 4000K (FA3) HL3A. That is how my eyes are seeing. And all my lights are 2700K to 4000K.
No, you are correct. I wasn't clear about what i meant. everything is relative, and in my experiences with trying many different emitters and tints is I (me personally) often cannot see the "hues" (red, green) as well without comparing a LED to another for reference.
What i meant to say is, when comparing any of my sst20 4000k or 2700k to my xpl-hi 4000k or 2850k they look yellow. not green, i didn't mean to say green earlier if i did. the sst20 4000k i have are from FireFlies only and they are very good bin (FA4) and not green or overly yellow. But when compared to an xpl-hi of the same cct, they are yellow where the xpl-hi is rosy-er. although the most recent xpl-hi 4000k 5D available from Hank (an emitter that has been known for being beautiful and rosy/pink) are much less rosy and more yellow.
g_damian - Thanks for sharing! that is awesome! and great results with the D80v2 and the A6, those are great numbers for those ligths especially at 2000 lumens!
A quick beamshot comparison I made tonight of 3 awesome lights. The main reason was because I recently modded the Astrolux ea01 with a sft40. It really increased the throw, I will get around to measuring the Lux with my mix meter eventually. Just wanted to share. The furthest trees are around 300 meters based on google map
Really cool stuff Artie, your doing some good simple mods. I near at the point to do reflows. Thought I had everything then discovered I need solder paste as well as solder wire! But my flashlight tool kit is growing by the day.
So awesome to hear! I am glad you are getting there! And once you buy all of this stufff you know exactly what you need and don't have to buy again for awhile so that's good!
I did my first kite complixate mod the other day. I changed 7 emitters in a FireFlies E07x pro. It was my first go round with something with a auxiliary led board.
next up - I'm doing two driver swaps on older Emisars. I'll document them both. Cheers buddy!
hmm… better looking? maybe… but they ar ejust quite different. the EA01 with xhp50 (i remember raving about that beam back when it came out) is really nice and very useful because its so large. the beam on the SFT40 mod is MUCH further thrower than both sst40 and xhp50 of course, but i wouldn’t say nearly as useful as the xhp50 version. If i had to pick just one, it may be the xhp50, just because the light is useful for more things. the sft40 is just more fun i would say. It out throws my Noctigon KR1 W2 easily, and is brighter. I cannot say the same for the EA01 with sst40.
I really did. And i'm actually pulling the SFT40 out of this EA01 to send over to another BLF'er so they can mod an awesome and WORTHY light with it! so i will most likely put the xhp50 back into the ea01, instead of the sst40 it came with. your comment reminded me of how much more i liked the EA01 with that LED. Plus, when the sst40 version arrived, i got slightly angry blue on turbo from it.. kindve disappointing from a stock light running a 9.6 amp battery.. ohwell, shouldn't happen with the larger xhp50. maybe ill finally try a dedome on it. i have a couple extra xhp50's so i can mess around a little bit with it. I remember TomE saying that dedoming the sst40 in the EA01 was not that impressive, so i wont try that..
I received the L21a SFT40 yesterday, and this light is Awesome. So far, the largest reflector i have used the sft40 in has been Simon's M21c (see first post), this light Really shows how awesome the SFT40 can be! Plus the light is just beautiful! I have comapred it to the K1 sbt90.2 and the Emisar D4S V2 with Osram W2 below.
Nice beam shots! Curious, does the L21A lights take a 26650? I have a vintage L2 from 2016 that looks exactly the same as the L21A, but it's a 26650 light, about 10 mm shorter than the L21A spec, and much lighter at 364g, 459g w/26650. Head diam is probably the same.
I don’t think it does, when 21700s were introduced to convoy lights Simon changed the nomenclature for almost all models and they now specify if its 18/21/26mm, with the exception of some S and C8 series
Then he separated the flashlights into 3 sizes S/M/L and each size category gets different models A/B/C/etc which is the letter at the end, it’s quite confusing…
