The Convoy M21B is basically the same light but uses a 21700 LiIon battery. This battery has more capacity & will give you longer run time than an 18650 battery.
The new TrustFire 3T6 Pro might be interesting. 3x18650 in series, much better to carry than a pop can. Don’t have one yet but some of their other lights in this style. All well regulated and robust. Build like tanks. I’m currently waiting for mine.
Sofirn SP35 6500K SST40 is what I would recommend. 21700 and on board USB-C charging. Pocket friendly, wall of light, and will reach 100m no problem. UI is good, with options for infinite or stepped ramping.
Yeah, lots of lights that can handle that but you might want something that has a little narrower beam so you can put the light downrange and not flood out your vision right in front of you. First question...are you in Georgia, US or some other Georgia? If the US, do you want to stick with ordering from a domestic store or Amazon, or are you comfortable ordering straight from China?
The Convoy M3 (or M3-C with onboard charging) is a good light and the beam would suit this pretty well plus have enough flood to help with searching for discs (and avoiding poison ivy), but it's a little heavy maybe. A big plus is that is has a good long run time so even if you need to run it on a higher setting you'll have plenty of battery to last a whole round (wise to carry a spare battery though). It has a somewhat funky but nice firmware that allows smooth (ish) ramping so you can adjust for the light you need while maybe backing off from full high mode to save a little juice. Many of the other smaller lights are going to need a second battery anyway to last a round unless you're playing solo and aren't searching for discs.
The Sofirn C8G with the right emitter might be a good option. It's a little smaller and lighter than the M3 (a common "C8" body style...millions of options available in that type from many companies) and it uses a dual switch...clicky on the rear tailcap for simple off/on, and a side e-switch for controlling modes and features. It has a nicer ramping option using the NarsilM firmware, or you can set it for stepped modes, too, your choice.
You may want to consider the light color temperature for this, too. Still a lot of lights on the market using the basic cold white 6500K emitters....works but not so pleasant to the eye or great for colors and details (especially in the woods). Something around 5000K is a more neutral white, very nice, or you could go warmer around 4000K (fewer options available for sale unless you want to change emitters yourself). If you're using glow discs or lights on the discs it won't matter a lot except for personal preference.
You might want to figure out a little tripod mount and light holder, too, which can be done for a few bucks. Something easier than trying to use a log or rock where you can't get the angle where you want it or keep the light from rolling or slipping off. The small camera flexible leg tripods are great for this and very versatile...will slip into your bag or pack easily.
for disc golf, I would suggest the Lumintop GT Mini. It is not very heavy and the battery will allow you to finish your disc golf game.
If you only need 10m wide you can set the flashlight in medium intensity giving you huge more than 2h battery.
Here you can see a review we made. It is in Spanish but google translate is your friend here
Although a little heavy as someone said, I too would recommend the Convoy M3-C because of it’s steady out put for several hours. You need the mass for heat regulation. The XPH 70,.2 emitter sounds about right for a combo of throw and spill.
Thanks, i knew the M1 first generation was 18650 since i had two of them, its good to bear in mind that the M21B is the 21700 version.
I would highly recommend this light, its bright, the beam has an excellent balance of throw and spill and even if you use an 18650 battery now you can upgrade to 21700 for more runtime.
Its simply one of the best all purpose lights there is.
2×18650, throw comparable to a C8, rock-solid high output from just-charged to completely spent, best heat dissipation I’ve ever seen in a handheld light.
Flat grip, so will sit on a rock and not roll off, too.
E07x Pro, buck driver lets it save a lot of power (or put out 1000+ lumens for an hour or two), has magnet in tailcap, 100m shouldn’t be an issue even with SST20 4000k but on that max brightness you’d need a spare batt or two. if you’re not running it at max, you should get 2-8 hours no problem.
If you need throw, T9R or T1R (latter not released)
just about anything else will probably have a crappy linear driver or awful LED, or be even more expensive
