I need a light that isn't too heavy to carry in the woods for 2 hours
38 posts / 0 new
emerrryjones
emerrryjones's picture
Hello,
I recently bought a good head light but cause it’s restricted to my head movement I need another one that is carried in hand and can be put down on a rock etc to light the fairway. I would need a light that it’s not too heavy to carry in woods for 2hours (and has battery for it). Typical disc golf course from tee to basket is around 80-140 meters and about 10 meters wide. It would be great if it could light at least 100m (also about the 10 meters that fairway is wide) so I can see where the disc is going. I don’t want to spend huge amount of money, maximum is maybe around 100$ (90€). In extra it would be great if the light can take a bit of rain that might come out of the sky.
Can you point me any light that fits my need or is it a lost cause?
Thanks in advance!!!
easyshades
Convoy M3-C
Bort
Bort's picture
Last seen: 6 hours 55 min ago
easyshades wrote:
Convoy M3-C
How much brightness do you need? And do you need spot brightness or flood brightness?
I would consider something like a Convoy M1 with 21700 battery.
The Journal of Alternative Facts TM
"It is critical that there is a credible academic source for the growing and important discipline of alternative facts. This field of study will just keep winning, and we knew that all the best people would want to be on board. There is a real risk in the world today that people might be getting their information about science from actual scientists"
Couchmaster
Last seen: 3 days 18 hours ago
I love both the Lumintop EDC18 and the Emisar D4 which sounds like they both would work for that application.
ShyOne
ShyOne's picture
Last seen: 1 month 5 days ago
Bort wrote:
easyshades wrote:
Convoy M3-C
I second this suggestion!! ✅ ✅
The Convoy M1 takes an 18650 LiIon battery.
The Convoy M21B is basically the same light but uses a 21700 LiIon battery. This battery has more capacity & will give you longer run time than an 18650 battery.
Here is a LINK for the Convoy M21B
The link takes you to the “Official Convoy Store”.
Simon, the owner; is a great person to deal with. ✅
EDIT to ask…
Are you more interested in a flood type beam or a more concentrated spot type beam??
There are LED choices to accommodate your needs.
A Convoy C8+ would possibly be my second choice… but it may well be overkill.
Oh yeah… you will spend far less than $100 & have a great light….. Beer
Welcome to BLF!!!
Souichirou
Souichirou's picture
Last seen: 3 days 4 hours ago
If you need a bit of flood and throw would you consider a Sofirn SP36 it runs multiple cells for longer run times and often comes bundled with cells.
Unheard
Unheard's picture
Last seen: 4 hours 48 min ago
The new TrustFire 3T6 Pro might be interesting. 3×18650 in series, much better to carry than a pop can. Don’t have one yet but some of their other lights in this style. All well regulated and robust. Build like tanks. I’m currently waiting for mine.
Smile, you cannot kill them all.
mortuus
mortuus's picture
Last seen: 2 days 6 hours ago
maybe sofin sp33, has more brightness then u need and pretty compact ? i guess ulive usa ?
they have more lighter lamps too check their amazon for good deals.
https://www.amazon.com/dp/B07ZQ4WKR7?ref_=ast_sto_dp&th=1&psc=1
...where Frugal meets with Flashlight!
              つ ◕_◕ ༽つ
TIFisher
Last seen: 4 hours 9 min ago
Sofirn SP35 6500K SST40 is what I would recommend. 21700 and on board USB-C charging. Pocket friendly, wall of light, and will reach 100m no problem. UI is good, with options for infinite or stepped ramping.
zoulas
zoulas's picture
Last seen: 3 hours 40 min ago
There are probably 1000 lights that fit your requirements and they all come in different colors and with different emitters.
Correllux
Correllux's picture
Last seen: 2 min 44 sec ago
 Yeah, lots of lights that can handle that but you might want something that has a little narrower beam so you can put the light downrange and not flood out your vision right in front of you.  First question...are you in Georgia, US or some other Georgia?  If the US, do you want to stick with ordering from a domestic store or Amazon, or are you comfortable ordering straight from China?
The Convoy M3 (or M3-C with onboard charging) is a good light and the beam would suit this pretty well plus have enough flood to help with searching for discs (and avoiding poison ivy), but it's a little heavy maybe.  A big plus is that is has a good long run time so even if you need to run it on a higher setting you'll have plenty of battery to last a whole round (wise to carry a spare battery though).  It has a somewhat funky but nice firmware that allows smooth (ish) ramping so you can adjust for the light you need while maybe backing off from full high mode to save a little juice.  Many of the other smaller lights are going to need a second battery anyway to last a round unless you're playing solo and aren't searching for discs.
The Sofirn C8G with the right emitter might be a good option.  It's a little smaller and lighter than the M3 (a common "C8" body style...millions of options available in that type from many companies) and it uses a dual switch...clicky on the rear tailcap for simple off/on, and a side e-switch for controlling modes and features.  It has a nicer ramping option using the NarsilM firmware, or you can set it for stepped modes, too,  your choice.
You may want to consider the light color temperature for this, too.  Still a lot of lights on the market using the basic cold white 6500K emitters....works but not so pleasant to the eye or great for colors and details (especially in the woods).  Something around 5000K is a more neutral white, very nice, or you could go warmer around 4000K (fewer options available for sale unless you want to change emitters yourself).  If you're using glow discs or lights on the discs it won't matter a lot except for personal preference.
You might want to figure out a little tripod mount and light holder, too, which can be done for a few bucks.  Something easier than trying to use a log or rock where you can't get the angle where you want it or keep the light from rolling or slipping off.  The small camera flexible leg tripods are great for this and very versatile...will slip into your bag or pack easily.
Web de Linternas
Web de Linternas's picture
Hi EmerryJones,
for disc golf, I would suggest the Lumintop GT Mini. It is not very heavy and the battery will allow you to finish your disc golf game.
If you only need 10m wide you can set the flashlight in medium intensity giving you huge more than 2h battery.
Here you can see a review we made. It is in Spanish but google translate is your friend here Smile
Lumintop GT Mini Review
Good luck with the disc golf.
Unheard
Unheard's picture
Instead of tripod and clamp, a ricepack will do.
I have one sice ages, works for lights as for cameras.
Easy to DIY.
pennzy
pennzy's picture
Last seen: 53 min 54 sec ago
Although a little heavy as someone said, I too would recommend the Convoy M3-C because of it’s steady out put for several hours. You need the mass for heat regulation. The XPH 70,.2 emitter sounds about right for a combo of throw and spill.
Bort
Bort's picture
ShyOne wrote:
Bort wrote:
easyshades wrote:
Convoy M3-C
EDIT to ask…
Welcome to BLF!!!
Thanks, i knew the M1 first generation was 18650 since i had two of them, its good to bear in mind that the M21B is the 21700 version.
I would highly recommend this light, its bright, the beam has an excellent balance of throw and spill and even if you use an 18650 battery now you can upgrade to 21700 for more runtime.
Its simply one of the best all purpose lights there is.
mortuus
mortuus's picture
Easy to DIY.
lol whats that ?
              つ ◕_◕ ༽つ
Lightbringer
Lightbringer's picture
Last seen: 10 hours 45 min ago
EC4GT, still available if you look.
2×18650, throw comparable to a C8, rock-solid high output from just-charged to completely spent, best heat dissipation I’ve ever seen in a handheld light.
Flat grip, so will sit on a rock and not roll off, too.
Dalamar
Last seen: 2 days 3 hours ago
E07x Pro, buck driver lets it save a lot of power (or put out 1000+ lumens for an hour or two), has magnet in tailcap, 100m shouldn’t be an issue even with SST20 4000k but on that max brightness you’d need a spare batt or two. if you’re not running it at max, you should get 2-8 hours no problem.
If you need throw, T9R or T1R (latter not released)
just about anything else will probably have a crappy linear driver or awful LED, or be even more expensive
I only like high CRI. Collection:
Fireflies NOV-MU 21 4500k E21A
Fireflies ROT66 219B SW45 D220
Fireflies E07 Copper 219B SW45k? (odd/higher lumen bin with lower r9 and higher cct?)
Fireflies E07 219B SW45k
Fireflies E07x Pro sst20 FA4 4000k
Varmint removal:
Convoy M21A C8 ver SST20 4000k (5a)
Convoy S2+ SST20 4000k  FB4 (3200ma)
Memes:
BLF GT94
Emisar D18 660nm SST20
CRI test dump https://drive.google.com/drive/folders/1kcl_uOhgfpR4RSsa8F4b-UUVP9mkL6Cr...
richbuff
Last seen: 39 min 13 sec ago
You are looking for exactly what Larzi needs, almost word for specific word: https://budgetlightforum.com/node/75029
Because I like big lights, my flashlightical views lean heavily toward both the extreme bright and the extreme heft.
Lightbringer
A lot of identical interest in nighttime frisbee golf, I guess. LOL
wle
wle's picture
Last seen: 1 day 19 hours ago
i’m in georgia, an FW3A works fine for me
light, small, bright, couple hours on medium lumens
pattern is moderately floody, i find it very useful
lumintop EDC18 might be just as good
wle
    Daniel Behrman, "The Man Who Loved Bicycles".
-Greg Lemond.
richbuff
Lightbringer wrote:
A lot of identical interest in nighttime frisbee golf, I guess. :))
From Finland to Georgia to Azerbaijan to the queen of England to the hounds of hell, all the way to Tacoma, Philadelphia, Atlanta, L.A.
wle
wle's picture
Lyrics
I left my home in Norfolk, Virginia
California on my mind
I straddled that Greyhound and rode him into Raleigh
And on across Caroline
We had motor trouble that turned into a struggle
Halfway across Alabam’
Well, that ‘hound broke down and left us all stranded
In downtown Birmingham
Right away I bought me a through train ticket
Right across Mississippi clean
I was on that midnight flyer out of Birmingham
Smokin’ into New Orleans
==what’s the song!?
-Greg Lemond.
turkeydance
turkeydance's picture
Last seen: 15 hours 14 min ago
as zoulas posted, there are lots of choices
and some would be much cheaper per unit.
how about buying 3 different ones which
cost ~$100USD combined and using
the one light you like best?
please understand, this advice comes from
someone who uses that logic to buy more.
turkeydance
promised land
makapuu
Last seen: 14 hours 45 min ago
Third vote for the Convoy M3-C. I use a 3000k tint for my nightly walks in/near the forest.
I like it so much I got a 5000k tint incoming for times I decide to walk the urban areas.
wle
wle's picture
turkeydance wrote:
promised land
yup
chuck berry
elvis presley
There are numerous other versions of this song:
In 1964 Johnny Rivers released his live album In Action including this song.
The Grateful Dead performed the song live 425 times from July 1971 through the band’s last show in 1995;7 live performances appear on nearly 50 of the band’s live albums,8 including the 1976 United Artists released live album Steal Your Face as well as several of the band’s Dick’s Picks releases.
In 1970 Freddy Weller released a version on an album of the same name. It was a Top 5 country hit in the winter of 1971.
In 1971 Johnnie Allan released a Cajun version in the US. It was released in 1974 in the UK.
In 1971 Dave Edmunds included it on his album Rockpile, released also as a single in 1972, it reached number 5 in the Australian charts.
In 1972 the band Juicy Lucy recorded a version on their album Pieces.
In 1973 the Canadian-American rock group The Band recorded “Promised Land” for their sixth studio LP, Moondog Matinee.
In 1974 James Taylor recorded a version on his album Walking Man.
In 1977 it was recorded by country singer Billy “Crash” Craddock on his album Live!.
In 1983 Meat Loaf recorded the song for his Midnight at the Lost and Found album.
In 1984 The Black Sorrows recorded a version for their debut studio album, Sonola.
In 2007 Geno Delafose released a zydeco version on his album Le Cowboy Creole.
In 2009 W.A.S.P. recorded a version of this song on the album Babylon.9
In 2014 Harry Dean Stanton released a version on the soundtrack album for the documentary film about him, Partly Fiction.10
In 2014 Jerry Lee Lewis released a version of this song on his album Rock & Roll Time
-Greg Lemond.
easyshades
this, exact reason i bought it. continuous output for 2.5 hrs without stepdown or overheating, in a good size package that you can put in a jacket pocket or hoodie, with good throw and spill, waterproof, with great build quality, with usb c charging and at a great price! what else do you want
puglife2
puglife2's picture
Sofirn C8F 90 cri
pennzy
pennzy's picture
wle wrote:
Lyrics
==what’s the song!?
Saw the Dead do it a few times.
Unheard
Unheard's picture
Easy to DIY.
lol whats that ?
A bag full of rice. Nah, it’s probably plastic, dunno. More commonly known as bean bag.
