I am more concerned about risk of explosion.
My 18650s are Sanyo and Samsung. I don’t have any 21700s
Will do.
I don’t care about uncommon sizes, i care more about battery safety.
I have not made my decisions yet, the WK30 is probably going to be bought, the SC31 Pro i am now leaning away from. Might buy the Wurkkos FC11 instead.
yes they are safe, usually good batteries shipped with those lights from sofirn/wurkos they have good reputation their lights so i doubt they would ship crappy batteries to hurt their reputation.
but if u get anyrthing with “fire” in battery name just throw that garbage away lol.
I bought 4 Sp31-pro lights with the included 18650 cells. They work just fine and are safe. The only issue with them being button tops is they can have sharp edges on the postive button terminal, this is no issue for a light with springs, but lights like say a BLF lantern that has springs at one end and a copper ring at the top can get scratched by the rough edges of the sofirn 18650 cells. You just smooth off these burrs/sharp edges with a file or sandpaper. I’ve been impressed with their 40A 21700 cell. If you get a SP31-PRO get 5k and order from Sofirn so you can get the 18350 battery tube, the magnetic tail cap and a light diffuser if you wish. Those extras are cheap a couple of bux. With the small short 18350 tube its you can get 1400mAh cells from Vapecel T-14 which work really well, still get 2000lm.
All I can tell you Bort is none of mine from Sofirn have exploded so far. They are all working fine & holding capacity after quite some time & a good bit of use.
Sofirn/Wurkkos 18650s are DLG NCM18650-300 and not sure what grade they are. DLG is one of the second-tier battery manufacturers in China and their batteries had very bad reputation several years ago but seems the quality improved recently. The capacity of these Sofirn batteries are good, all mine close to 3000mah but 6A CDR is a meh. I won’t use them in high-drain flashlights like SC31 which can draw ~9A on turbo. But they should be fine in lantern or even in SP36. When you see tests claimed they are comparable to GA or 30Q simply because all these tests were carried out under 1-5A discharge . I am pretty sure you will see big difference under 10A or 15A discharge. DLG 18650 3000mAh 6.4A Battery (NCM18650-300).
Yes SC31pro is poorly regulated but you may try their SP35 which uses the same emitter with a buck driver. The included sofirn 21700 is a LISHEN LR2170SA (a OK battery). SP35 is a litter bit thrower than SC31pro. WK30 is a good regulated light but it is very very spill and obviously dimmer than Sc31. And their UV light uses the same emitter in sofirn Sp31uv. It is better than nothing but significantly worse than Convoy S2+ with Nichia 365nm in my comparison.
Thanks, this is useful info. How do you know all this?
Link is not working.
I went ahead and ordered the WK30 based on several recommendations on BLF, sucks to hear i may have made a mistake as it would be my only UV light. I don’t know if i can cancel it now
Apparently they initially used a crummy UV emitter then improved it but i don’t know if its good, i wish i had seen this before ordering.
As for another light i am not bothering right now, gonna hold on to my cash until something exceptional comes along.
I don’t own this light, but Wurkkos updated the LED to 365nm. From the pictures I’ve seen it’s ok. Might not be as powerful as the S2+, which I own, but seriously, the Convoy is brutally bright. Without eye protection, I get headache within 10 seconds.
While they aren’t dangerous and work okay, the QC could be better. Received 100pcs 18650 with spot welded button tops barely welded on causing very poor performance. Then a batch of rusty 14500’s I had to bin. Reported to Sofirn who never bothered to respond or offer compensation…I bought 200 of them
I’m a dealer for Sofirn, but refuse to bundle their batteries. I rate all flashlights in my store with my own tested lumens, and I like to bundle a battery that achieves my lumen result. I find it a bit deceiving advertising a model at 3000 lumens and then bundling a battery that can only output 2000. This is the case with Sofirn’s batteries
The re-wrapped PLB 26650 Sofirn now sell is very decent though. I had been using this model way before Sofirn got their hands on them
I have been meaning to look into a filter.
I ordered the WK30 yesterday and they shipped it today so i should get it in 1-2 months. Is it a good UV emitter?
I don’t know what filter to look for or where to buy it (being in Canada).
Initially I have the same intention like you - ordered wk30 as my only uv light as I thought I won’t use it often. After playing around for a few days I felt unsatisfied and then ordered S2. I think it is still a good uv light, but saw huge difference after testing both in bathroom. After that I ordered ZWB filter for S2 (you cannot add zwb filter for wk30). The wk30 I received obviously has a different emitter than pictures posted on wk30 review threads here but I later found it is the exact same one used in sofirn sp31uv (no surprise) so believe it is still a 365nm emitter. The S2+ Nichia 365 I bought is the upgraded version with 7135x3 and Zeroair has a test review on it. To be frankly, I think you will eventually buy a S2+ if you are interested in a uv light. I actually like wk30 - it is a good light, 351 emitter has very neutral white light w/o any noticeable green tint. It is also very floody and red light is a big plus.
Yes I believe it is a 365nm emitter, 395nm emitter has lots more visible light and all 2021 wk30s should be 365nm (mine was manufactured in early 2021 according to serial no ). The one I received has the same emitter in sp31uv tested by davestechreviews, but it is different from wk30 review thread posted on BLF.
Yeah these DLG 18650 batteries are dirty cheap so I guess it is the reason why sofirn re-wrapped them. I do see a few has high internal resistance on my vapcell s4+ so obviously QC could be an issue. Other Chinese branded cells like LISHEN have the similar issue. I remember seeing a report saying that the QC failure rate of these Chinese cells is much higher comparing with major brands.
Resistance is never accurate on a charger though, you’d need something like this
I found the Sofirn 21700 5000mAh (Lishen LR2170SD) to be excellent, I reviewed it here I ended up purchasing 100pcs of these from 18650batterystore.
Can’t really expect China cells to match the same QC when they’re priced so much cheaper. They’re decent for what they are, I just wish Sofirn gave the option to bundle Samsung, Panasonic etc.
The older 395nm LED did have visible light “leakage”, but it was bluish/purplish, not too obtrusive.
The newer 365nm LED, which I don’t have in the WK30, but presumably in the SP31UV, which I do have, has an eerie greenish tint to its visible leakage.
The ’31 is a nice UV thrower if you want to spot scorpions, etc., before they’re actually crawling all over you, but it’s in desperate need of a ZWB2 filter. My old/original WK30 is perfectly usable without any filter.
That said, the UV S2+ with ZWB2 filter is the sangraal of UV lights.
