FREEME ✌ ASTROLUX® BL02 2*XP-G3 1200lm Bicycle Headlight Group Buy - ALIVE - 107pcs SOLD
Shared.
I get this “This coupon cannot be used on already discounted presale products.” Also I don’t think I want to pay 5$ for shipping. :rage:
Reserved
Shipped on Jul 2.
Arriving today.
Interested.
But I need to know if I have to cycle through the obnoxious blinky modes to get back to high. Does the light have memory, or can I just turn it off and back on to go straight to high?
Edit- just saw on Facebook that the light has no memory, so I should be able to turn it off and back on to go to high. Kind of a pain, but better then having to put up with the obnoxious blinky modes.
  • Long press (2-3s) to turn off at any mode.
  • No memory mode
  • High > Medium> Low> Flashing (slow) >SOS
Test results in https://1thedeals.com/product/astrolux-bl02-2xp-g3-1200lm-bicycle-headlight/
Freeme, thanks for the code. Bangood is getting kinda pricey on the shipping, adding nearly 30% to the final cost.
30%, why? I only aware that EU residents have to pay higher VAT this year.
I have the light now and I can confirm you can avoid the blinky and off modes. Essentially a double click puts you into high mode with both leds, single click cycles med/low/off, however you can avoid off by double clicking to get back into high. There are no blinky modes with both leds in use.
If you only want to use a single led it’s trickier as you have to cycle all modes, although you can switch from high to low beam (or vice versa) which puts you back into high again, avoiding off and blinky modes. The thing is, you’ll likely be using the lights with both leds running at all times. Both high and low beam have a good anti-glare horizontal cut off, so using a single led seems kind of irrelevant for any purpose.
Edit: after further use, doubleclicking to get back to high mode is a bit problematic. It’s not always easy to doubleclick fast enough while riding and the light momentarily flicks off if you manage to pull it off, which is less than ideal while riding. At this price point the light is still a steal, well made, etc, but UI is disappointing.
Loong press (3s) to OFF at any mode.
$22 for the light, and over $6 for shipping to Texas.
Maybe they configured it wrongly. I will get them to check for me tomorrow.
I’d love to get one, please add me.
Shared.
Just tried again. Shipping has dropped by about $2. I guess I’m getting too used to Amazon free shipping :smiley:
Order placed. Should be fun to compare this to my Lumintop B01.
Code please thank you !
Sent.
Mine arrived around three weeks ago. Works very well. Easy mount and good light options. I don’t have any other bike lights so nothing to compare it to but does the job.
How does this compare to Lumintop’s B01 bicycle headlamp?
