new flashlight design
DQG Tiny did some pretty small side switch assemblies. Some had a rubber boot, some had a metal button but all had a press fit retainer. I’m guessing that will save you a little bit of machine time if you press fit rather than thread.
Thanks again for all the suggestions, its taken me a few months but I finally think I have nailed my design and what to see what everyone thinks.
Hopefully the images come through, my first time trying to post them.
The design is a 2 piece light that is brought together by the thumbwheel in the center. It takes 2 14500 cells run in parallel and will run on only one in a pinch. Right now i am building them with the Qlite momentary switch driver from mtnelectronics but am open to suggestions if someone knows of a driver under 18mm diameter that can run both aa/ 14500 but i haven’t been able to find one. I have designed the head to accept 20mm carclo optics and i will be offering both in single xml2 and triple xp-e2 configurations. The “guts” of the light are my custom made pill that holds the Led, driver with momentary switch attached that can be changed by unscrewing the front bezel allowing you to easily go between different led configurations by putting in a new pill/lens.
I am machining everything my self including the button that is located on the bottom of the light toward the front. The location of the button makes the light very versatile, lending its self to many different hand positions. The slot running between the batteries is a mounting point for accessories including the pocket clip, which can be loosened and slid higher or lower, Mlok and keymod weapons mounting adapters which will be flush to the rail, and a magnet to come later.
The weight is around 5oz without batteries, 4.15 inches long, 1.65 inches tall, .8 inches wide at the body and .96 inches at the swell on the head.
I hope to have a completed final version completed this week and i will share some photos as soon as I can
Pretty speccy looking light :sunglasses:
DQG had some TERRIBLE versions of side switches, though they were small, they broke very soon.
it;s different but i would expect it not to sell to the ‘pocketing EDC’ market - it is too thick and heavy.
not familiar with lights that go on guns, maybe small and light do not matter to them.
just saying.
beg to differ, it is titanium and made in USA, it will certainly sell
here is a similar two AA that weighs 115 grams and sells out at $250, in aluminium
here is a Spy007, USA made dual cell Ti $2,700:
the site http://www.coolfall.com/p007.html does not say what it weighs, nor what LED it uses… and there are no beam photos… Im guessing the people who can afford it, dont care… (if I have to ask, I cant afford it)
I appreciate the input! Ive made the light as narrow as i can to still be able to use the carclo optics that I wanted. I chose these optics because they are affordable, easily available and come in many different styles and cam be changed quickly by the end user by simply unscrewing the front bezel.
As for the button I am making my own that consists of a tactile switch with a silicone top hat under a metal button that is held in by a threaded ring that also seals around the silicone hat. This is in my opinion the most waterproof way you can make a button and still have a metal surface. I plan on including multiple height buttons; recessed, flush and protruding that can be changed by simply unscrewing the retaining ring. I would also like to offer lighted buttons as an upgrade.
I am considering adding some recesses on the sides to lower some weight but I really love the clean look of it how it is, though it may be something i do as a different version. Right now they will be made of aluminum, i do plan on doing some in titanium eventually but it will add over 30% to the weight.
Overall I am happy with how is coming out, I think it presents an interesting alternative to other side by side lights on the market. Its way harder than you would think to design a non round light and have it somewhat waterproof and not be giant but most of my dimensions come in just under what others are making and i am able to fit larger optics. The only place mine is bigger really is the length but my closure mechanism adds about .25” and is really my favorite part. At just over 4” I think it feels really nice in the hand.
thanks for sharing your thoughts
though I like the look of the closure dial, once I figured out it is not the switch,
I think I would rather have it at the tail
totally respect your switch button design goals, it matches my Sunwayman V11r construction, it actually comes with two switch caps, both flush, one rubber, one Ti
I like that the switch position in your design allows either thumb or index finger operation, and is easy to locate by feel… it will be even more ergonomic with the closure dial at the base of the grip
like the very clean lines
and a cool resemblance to a derringer
thanks for sharing pics
given the choice of optic and straight sides, the weight makes sense…
marketing spin:
more thermal mass, supports a higher sustainable output
question
for that optic size, does the present design have enough room for a 16340 battery also?
a 16340 option, could be shorter, and weigh less…
and you could use a separate AA adapter also…
I’ve had a number of dqg’s with both rubber and metal buttons. Didn’t especially like the feel of the rubber buttons but never had any problems or issues with any of them. What was so terrible about them?
Don’t forget the mt21a. That was a nice size 2aa light
Sounds like you got the switch sorted. Maybe you could do the weight reduction on the ti model …?
In order to fit a 16340 battery the light would have to be taller as there is very little room in between the batteries for the bolt that brings the 2 halves together.
As for the thumbwheel ergonomics you really cant feel it when your holding the light using it as it is narrower than the body. The recess is designed so that your thumb and index finger can perfectly access the wheel when holding the light from he base, and its one of those unique features that will make a pretty recognizable light.
Hopefully I will have some pics of a finished body tomorrow, depending on when the ups man drops a couple cutting tools I need to finish up. I may try and film some of the machining too if anyone is interested in that stuff.
Yes please :slight_smile:
ok, good luck with that, as they say.
wle
Sorry for the delay, was out of the shop for a few days but here’s some progress shots. I have the body and head finished, there a few small cosmetic changes I’m going to make but they are 95%. Now just have the bezel, button and thumb wheel to make and should have a fully working prototype in a day or two.
Hopefully I got the pictures right still not positive I’m doing it right.
Very interesting.
Oh man, no pics… I am dying to see the progress.
Second try for the pics
very nice!
thanks for sharing your work
tritium slots? :wink:
That is so cool. Have been on a 14500 kick lately and that is nice. Wish I could justify ine.
There’s definitely plenty of room for tritium slots, any suggestions on where may look cool?
? :student:
