new flashlight design
59 posts / 0 new
pointermachineworks
Last seen: 1 month 6 days ago
I appreciate the input! Ive made the light as narrow as i can to still be able to use the carclo optics that I wanted. I chose these optics because they are affordable, easily available and come in many different styles and cam be changed quickly by the end user by simply unscrewing the front bezel. As for the button I am making my own that consists of a tactile switch with a silicone top hat under a metal button that is held in by a threaded ring that also seals around the silicone hat. This is in my opinion the most waterproof way you can make a button and still have a metal surface. I plan on including multiple height buttons; recessed, flush and protruding that can be changed by simply unscrewing the retaining ring. I would also like to offer lighted buttons as an upgrade.
I am considering adding some recesses on the sides to lower some weight but I really love the clean look of it how it is, though it may be something i do as a different version. Right now they will be made of aluminum, i do plan on doing some in titanium eventually but it will add over 30% to the weight.
Overall I am happy with how is coming out, I think it presents an interesting alternative to other side by side lights on the market. Its way harder than you would think to design a non round light and have it somewhat waterproof and not be giant but most of my dimensions come in just under what others are making and i am able to fit larger optics. The only place mine is bigger really is the length but my closure mechanism adds about .25” and is really my favorite part. At just over 4” I think it feels really nice in the hand.
jon_slider
jon_slider's picture
Last seen: 1 hour 22 min ago
thanks for sharing your thoughts
though I like the look of the closure dial, once I figured out it is not the switch,
I think I would rather have it at the tail
totally respect your switch button design goals, it matches my Sunwayman V11r construction, it actually comes with two switch caps, both flush, one rubber, one Ti
I like that the switch position in your design allows either thumb or index finger operation, and is easy to locate by feel.. it will be even more ergonomic with the closure dial at the base of the grip
like the very clean lines
and a cool resemblance to a derringer
thanks for sharing pics
given the choice of optic and straight sides, the weight makes sense..
marketing spin:
more thermal mass, supports a higher sustainable output
question
for that optic size, does the present design have enough room for a 16340 battery also?
a 16340 option, could be shorter, and weigh less…
and you could use a separate AA adapter also..
pinkpanda3310
pinkpanda3310's picture
Last seen: 1 day 20 hours ago
wle wrote:
I’ve had a number of dqg’s with both rubber and metal buttons. Didn’t especially like the feel of the rubber buttons but never had any problems or issues with any of them. What was so terrible about them?
jon_slider wrote:
Don’t forget the mt21a. That was a nice size 2aa light
pointermachineworks wrote:
Sounds like you got the switch sorted. Maybe you could do the weight reduction on the ti model …?
pointermachineworks
In order to fit a 16340 battery the light would have to be taller as there is very little room in between the batteries for the bolt that brings the 2 halves together.
As for the thumbwheel ergonomics you really cant feel it when your holding the light using it as it is narrower than the body. The recess is designed so that your thumb and index finger can perfectly access the wheel when holding the light from he base, and its one of those unique features that will make a pretty recognizable light.
Hopefully I will have some pics of a finished body tomorrow, depending on when the ups man drops a couple cutting tools I need to finish up. I may try and film some of the machining too if anyone is interested in that stuff.
pinkpanda3310
Yes please Smile
wle
wle's picture
Last seen: 5 hours 30 min ago
ok, good luck with that, as they say.
wle
    Daniel Behrman, "The Man Who Loved Bicycles".
-Greg Lemond.
pointermachineworks
Sorry for the delay, was out of the shop for a few days but here’s some progress shots. I have the body and head finished, there a few small cosmetic changes I’m going to make but they are 95%. Now just have the bezel, button and thumb wheel to make and should have a fully working prototype in a day or two.
Hopefully I got the pictures right still not positive I’m doing it right.
chadvone
chadvone's picture
Last seen: 1 hour 42 min ago
Very interesting.
mattlward
mattlward's picture
Last seen: 3 hours 7 min ago
Oh man, no pics… I am dying to see the progress.
EDC rotation:
FW1A, LH351D 4000k (second favorite)
FW3A, LH351D 3500k
FW3A, SST20 FD2 4000k
FW3A, Nichia 4000k sw40 r9080 (favorite light!)
FW3A, Cree XP-L Hi 5A3
Emisar D4V2, SST20 4000k
S2+, XM-L2 T6 4C
pointermachineworks
Second try for the pics
https://imgur.com/a/rVRrccR
jon_slider
very nice!
thanks for sharing your work
tritium slots? Wink
mattlward
mattlward's picture
That is so cool. Have been on a 14500 kick lately and that is nice. Wish I could justify ine.
EDC rotation:
FW3A, LH351D 3500k
S2+, XM-L2 T6 4C
pointermachineworks
very nice! thanks for sharing your work tritium slots? Wink
There’s definitely plenty of room for tritium slots, any suggestions on where may look cool?
jon_slider
? Grad
mattlward
mattlward's picture
I would like to see a 3d plus or X under the emitters on the front.
EDC rotation:
FW3A, LH351D 3500k
S2+, XM-L2 T6 4C
pointermachineworks
Actually on the front under the emitter there is quite a bit of meat, perfect spot for tritium now that you mention it!
Just made the bezel, by far the hardest part yet. It’s tiny, super fine threads, tiny, super small and oh yeah I don’t have a lathe so I had to make it on my mill lol. It came out pretty good definitely the piece I’m most proud of so far. The lighting sucks in my garage and the finish right off the machine looks much better in person but here’s a couple of pics.
mattlward
mattlward's picture
Looking really good, great skills.
EDC rotation:
FW3A, LH351D 3500k
S2+, XM-L2 T6 4C
pointermachineworks
Finally finished! Taken forever but I have a completed light all made from scratch! let me know what you guys think!
dthrckt
dthrckt's picture
Last seen: 3 hours 10 min ago
Lead with the last paragraph in the OP. That’s my best suggestion.
I would like to see that kind of product.
raccoon city
raccoon city's picture
Last seen: 2 hours 15 min ago
Looks really nice!  :THUMBS-UP:
pinkpanda3310
Definitely a unique design. I enjoyed reading this thread very much Beer
Geuzzz
Geuzzz's picture
Last seen: 3 hours 33 min ago
Nice! Thanks for sharing. I would buy one if not to expensive Wink
jon_slider
looks great, congratulations
I look forward to your success.
pointermachineworks
Now that I have everything ironed out I’m placing orders for a few batches worth of components and am launching a limited Pre-order! I hope to have the first lights shipped out this month depending on the anodize. I have some test bodies being done right now so I can choose what colors will be offered and should have them by Friday. I am only tanking a small number of orders so I anticipate on selling out pretty quickly and anyone who orders will be emailed a selection sheet for choosing the led, the color, and the optic. Thanks to everyone who has helped out its really appreciated! Not sure if i am allowed to link this but I created a site for ordering Pointermachieworks.com If its a problem posting that on here i will remove.
Tom E
Tom E's picture
Last seen: 1 hour 48 min ago
No problem adding a link: https://www.pointermachineworks.com/
Did you hook up with Richard at MtnE for the driver? Richard hasn't been very active as of late, but he's still selling/supporting his products as I understand.
The price is out of my league for an EDC unfortunately.
xevious
xevious's picture
Last seen: 1 hour 26 min ago
Curious design. As for tritium, I’d go for something more like this, naturally in line with a groove already there (just need inset cuts for clean vial mounting—either per vial, or one long channel to accommodate multiple vial sizes), well protected :
pointermachineworks
I haven’t been in contact with Richard but I am purchasing my drivers from Mtnelectronics. The price is on the higher end unfortunately but there’s 9 individually machined parts that are fairly intricate and the machine time is pretty high. I would like to offer a discount for forum members of 10 percent if you use BLF1
Forsythe P. Jones
Last seen: 1 hour 17 min ago
(Not sure what happened, I posted a reply and don’t see it now, so sorry if this is a dup.)
This looks really nice, I love rotary controls on lights, and it reminds me a little of the Cool Fall Spy series before the price went into outer space (coolfall.com if you’re not familiar). You might post about it on CPF since I think custom lights are more appreciated over there than here.
What driver did you pick out? How many levels, etc.? Any PWM? How is the thumbwheel switch going to work? One thing I liked about the Spy was that it was pure DC, no PWM at all. It used a custom driver and you may end up having to do the same for this light, maybe based on Anduril.
