JFJinCo, thank you for the scoop on the Osrams.
@Lojik, how do you carry your 21700’s? EDCing a 21700 in general seems pretty cumbersome, especially something in copper. Do you use cargo pockets? A pouch? Holster? Fanny pack? I’m curious. I don’t know anything about this SBT90.2! I’m gonna have to look it up. The D18 looks incredible, and is absolutely something I’m going to have to get eventually. And I think your spot on, that it would serve me well for lots of purposes. I don’t mind a big light. If it’s not something I expect to EDC, then as long as it fits in a backpack or cargo pockets I’m into it. I was using 2D and 3C maglites not too many trips around the sun ago. Speaking of, I think it’s weird that there’s so few larger elongated light options these days, like 2x 21700 end on end. Stuff like that. But with all that said, I’m probably not going to get a D18 yet. The KR1 comes in at about half the price, and I’ve already spent so much on the D4V2 and the DT8.
So lemme see if I’m in the ballpark with the emitter options for the KR1:
W1- throwiest option, only cool white, tighter hotspot than W2
W2- brighter, with likely a more functionally spread out hotspot than the W1, but faster battery drain
SST-20- pretty throwy, good balance of cri and power, good tint at higher power, bad (green) at lower power
SST-40- ?
XP-L Hi-?
Not sure how the last two compare to the rest. I have read that the XP-L Hi have better tints than the SST-20 and they have a good color range, but aren’t as throwy and aren’t hi-cri except the warmest one. And I think the SST-40 is what’s in my Warrior Mini, but in a gross 6500k. If I were to use the KR1 most often for shorter durations, and almost always at turbo or high, for the purposes listed in my previous post, am I correct in thinking that an SST-20 would serve me well? Or should I consider the XP-L Hi? Or just go with the Osram for MAXIMUM THROOOOW?
Thanks!
Mark M, jon_slider’s explanations and pictures have been clutch in helping me pick what emitters I want in my first Hank lights! I just wanted to second what you said. I know nothing, but I do know that that s* has been extremely helpful to this noob.
DrDevil, I was initially going to get the sandblasted Ti D4V2, but I emailed him first and he said that he was out, but that a reseller jlhawaii808 had them in stock. I don’t know if he’s out of the antique brass or not, but I probably would have emailed him first. Btw, it looks like jlhawaii808 does have antique brass D4V2 in stock.
