Armytek wizard pro battery sensing problem
9 posts / 0 new
CvR_XX
CvR_XX's picture
Last seen: 1 month 19 hours ago
Hey All,
I’ve been a lurker on this forum for a long time and recently I’ve also bought the blf lantern recently. Very excited for it to come in.
The reason I’m writing this first topic is because of my trusty armytek wizard pro. It has been my daily driver for a few years now but it started to malfunction. The problem is that it starts lowering brightness and giving the low battery alert while the battery was charged a few minutes ago.
I just turned the light on and it immediately falls back into dropping down brightness and orange led. When I measure cell voltage I get: 3.951 V. I’ve had this problem with multiple batteries. All without a protection circuit. The temperature in the room is 25 C Celsius.
Another thing I saw online and I’ve tried is to enter the battery menu where you select the type of battery but my light doesn’t seem to have it.
Does anyone have any idea what I could try next? I don’t want to try to open the light until I see no other option.
Thanks!
Carlos
Edited by: CvR_XX on 07/12/2021 - 08:35
raccoon city
raccoon city's picture
Last seen: 1 min 10 sec ago
It's good to have you here, CvR_XX!
110_milla
puglife2
puglife2's picture
Last seen: 8 hours 35 min ago
have you tried cleaning the contacts/spring with 70%+ rubbing alcohol / cleaning the cell / try with another cell, if it’s still fail you have a 10 years hassle included warranty
CvR_XX
CvR_XX's picture
Thanks for your awnser! I’ve tried that yes. How do I get the warranty? My local seller only offers two years.
Edit: I’ve just noticed that they’ve got an email for that. Sorry for not googling before asking.
Oli
Last seen: 14 hours 26 min ago
Does it happen at main and firefly levels? Could be a sensor problem or something could be shorting out somewhere. But if you can’t run it long enough to really see a measurable voltage drop in the battery then you can’t really prove it. It probably won’t make a difference but it wouldn’t hurt to run it without the tail cap using a wire from battery to the end of the tube. You’ll have to hold some pretty good pressure down on the wire on the battery while you’re operating the switch. That would simply rule out any sort of tail cap issues which are not likely. If you had a DC clamp meter to use with the wire test that would help to see if there is an excess amp draw. Obviously most people don’t have that. Edit. If it’s not a tail cap problem then you’re not going to be able to fix it. Getting through the warranty processe can be a hassle.
Armytek
Armytek's picture
Last seen: 1 day 20 hours ago
Hello! Actually, I don’t think the warranty process can be a hassle! If you still have this problem, you can fill in the form on our official website to start the warranty process!
If you have any difficulties, you can reach our manager either by phone or by email and he will help you!
Armytek Optoelectronics Inc.
www.armytek.com
ShyOne
ShyOne's picture
Last seen: 4 days 18 hours ago
^^^^… +1 …. Thumbs Up
CvR_XX
CvR_XX's picture
I just got back from a water scouting summer camp. Cause I needed my light I’ve tried some things to fix it up and luckily it worked.
Apparently, black goo was accumulating on the ring in the tail cap which the exposed steel of the main body connects to. This lead to a sketchy connection which resulted in a voltage drop measured by the driver board. I used some q-tips and rubbing alcohol to get it all out. I suspect that the black goo was little pieces of the o ring while it degrades.
Now my light works like a charm again but I ordered another headlight anyway so I’ve got a backup.
Thanks for the great tips!
freeme
freeme's picture
Last seen: 1 hour 20 min ago
+1
Armytek wrote:
Hello! Actually, I don't think the warranty process can be a hassle! If you still have this problem, you can fill in the form on our official website to start the warranty process! If you have any difficulties, you can reach our manager either by phone or by email and he will help you!
1thedeals.comyoutubeAstroluxNealsgadgetsolight
