I like this…but I’m questioning whether or not that 800m rating is accurate. 5000mah cells would’ve been better but I guess the 50S just doesn’t wanna be in stock. Also, considering that the XHP70.3 is almost out it doesn’t make sense for one to spend so much on a flashlight only to have it be outdated in a couple months.
Edit: Holy crap I just looked at the weight. 690g without batteries Looks like it won’t be going in any pockets. I think the weight just defeats the purpose of making it compact. Might as well make it bigger or add another cell if it’s going to be that heavy.
It has 8-Cree XHP-70.2’s, 3-5000mah cells can’t push that current load. Molicel INR21700-P42A 4200mAh and it’s 40-45 amp rated. Molicel also list its nominal voltage as 3.6v hence maybe the 10.8v listing. Playing with the Cree Tools it’s going to take 20 amps at 12.2 volts just to get 35,000 lumens with the highest bin. Good electronics and Acebeam can probably do it, but not for long. You’re looking at probably close to 300 watts that’s what 690 grams of mass is helping with. But I’m guessing with this flashlights mass it’ll probably settle down to about 6,000 lumens after the thermal sensor does it’s job.
The problem with these throw rating is that they’re measured at peak output. Once the temp regulation kicks in it will stay in Med2, 6,500lm 30,625cd 350 meters, as seen in the runtime figures.
Love Acebeam, but this will probably be $350. I doubt 800 m out of the small reflector xhp70.2. Might meet the lumen rating, but for maybe 1-2 seconds?
Just take for example the Lumintop BLF GT4 with four cree XHP70.2 that makes over 30 000 lumens output. https://youtu.be/tM9XL4rRw2A
But yeah it is a heavy flashlight.
With 4 cells they could’ve also went with 5000mah cells making the capacity even higher(12750mah vs 20000mah). Even with the same 4250mah cells it would’ve still made much more sense.
Thank you for the size comparison pics and for the beam shots. I am happy that it has normal modes for normal heat generation and normal run time. But what I’m really excited about is a few seconds of lighting up a large area very bright, and then throttling down to focus on smaller area closer up.
Wouldn’t be surprised if it lasts almost a minute on turbo. It has a lot of thermal mass and a handle so it can reach higher temperatures without burning your hand.
