*BLF LT1 Lantern Project) (updated Nov,17,2020)
I’m really confused now…
So many variations.
Is the original LT1 version 1 capable of being programmed to Anduril 2.0? If so, I may go that route. I’m not needing my LT1 to double as a power bank. I would NOT want the active power/standby switch light to be green, as showing in the newer release. That would annoy me to no end…
Yes, it is. I’m using mine with Anduril 2 for months. :slight_smile:
Yeah if you can upgrade it to 2.0 that seems to make the most sense for you. But just to be clear, the powerbank version I got maintains the orange standby light.
Cool! Thanks for the photo.
We were right then, that is indeed a completely different controller. From another manufacturer (which I admit, I have not even heard of).
What’s very strange about that IC is that it is laking any connection with the CC pins in the Type-C connector, which the whole power-role detection and switching scheme of USB Type-C is based on.
It handles all that somehow solely based on the VBUS (device power) pin. Not how the guys at USB-IF intended it, for sure. But hey, if it works, we cannot complain, right :smiley:
I assume this variant of LT1 driver has fixed resistors wired to he CC lines. Meaning that it advertises itself in a fixed, hardcoded role. But this also means that its actual role and advertized role is going to be inconsistent in 50% of the cases: either when sourcing or sinking power. That should be fine for “dumb” devices (chargers w USB-A sockets, old LT1) but could be problematic with “real” Type-C / PD devices, which actually make extensive use of the CC pins.
I hope I am wrong about that, but nevertheless it could not hurt to do some tests with different devices, with a C-to-C cable, to see how it behaves with them.
With the other driver variant, there are no such concerns, its controller (IP5310 from Injoinic) is a “real” Type-C device, with built-in CC-pin handling logic, Type-C DRP Try-Src statemachine, all bells and whistles.
Thanks for looking into this.
I have some headphones I could try charging with it. Would you say that this setup could potentially damage real Type-C devices? Would it harm something like an iphone, which still uses lightning cables?
Sorry if I frightened you with the things I wrote. Actually, I think it is very unlikely that it would harm any connected equipment, I would not be worried about that if I were you (although I obviously cannot say this with 100% certainty without knowing the exact schematic of the driver and the detection mechanism used by the IC and deep-diving into the gritty details of the USB specs). What I could easily imagine, are some special cases in which it just refuses to work together with some devices (e.g. won’t charge when connected to a USB-PD charger; won’t charge from a powerbank, or it won’t source power to a powerbank (*); things like that…).
(*) Normally when you connect two powerbanks with the same role-priority or no role-priority together, the outcome of “who is powering whom” is random. That might not be able to happen here. The powerbank is just an example, the same holds true for other dual-role Type-C gadgets.
Odd, the orange LT1 i received from Sofirn a few weeks ago had the other original driver, (see the photo) but i do see teh slight imperfection in the machining in the head same as your photos show. it looks like their CNC had a hiccup in that area where the bail handle folds down.
Its just too hard. I was going to buy a second LT1 but have no idea what I will get.
Maybe wait for a few months until Sofirn stabilises their models. If they ever do.
I am afraid we will not get any detailed, official clarification on "what is what" anytime soon. :(
I have now seen four different driver revisions...
First revision 4.3 Updated revision 5.0 with type C-C compatibility fix Unknown new (intermediate?) revision 2021 with PD/reverse charging and Andúril 2 New (official?) revision 2021 with PD/reverse charging, revised flashing pad layout and Andúril 2
Wow… I know i have been a bit out of the loop for the last year due to my big move, life alterations, getting ill, and trying to get back on my feet, meaning i was not as directly involved, or aware of driver changes. I have been however watching the LT1 te4am chat group, but there has been no updates from Barry with Sofirn or other team members during my downtimes… I wish Barry would have consulted with the team, ( all of us active members on the design/development team for the LT1: (Myself, ToyKeeper, SIGShooter, Barry0892, Phlogiston, Lexel, sbslider, BlueSwordM, bmengineer, Lux-Perpetua and amishbill) were the team that contributed to the LT1.
Interesting test… That shows the new version (Powerbank enabled) should be able to power a second LT1 as a “tag-light” meaning one LT1 can power two separate LT1 head units from one body set of cells, (but with a reduced run times, as its likely the same as running two separate LT1 lanterns with only two cells in each lantern, ( as the LT1 can run with even a single 18650, or two, three or for cells by design intentions.
Sorry I haven’t the time to read through the thread but was hoping to recieve simple suggestions on which and where to purchase this lantern? From the last few threads it seems like there have been several modifications and on Amazon there are two variations (under the link https://www.amazon.com/Rechargeable-portable-Inserted-batteries-Batteries/dp/B097MN6P1B/ref=sr_1_1?dchild=1&keywords=sofirn%2BBLF%2BLT1%2Blantern&qid=1626317714&sr=8-1&th=1)
New LT1 Kits: $84.99
Old LT1 Kits: $76.99
Would anyone kindly suggest which model and the differences I should use?
If you find out……… please let the rest of us know :person_facepalming: ………. and welcome to BLF
I would be tempted to buy the cheapest one available. Its likely to be the old version ie the original BLF LT1 in black.
A excellent straight forward camping/emergency lantern as originally designed. USB-A to C cable & the option of enabling the other chips.
But who knows ???
I’m planning on getting a second LT1 but will wait for a few months & see if Sofirn sort out their variations.
Green indicator will be changed to orange. But they’ll probably sell current stock first. Not sure if they’re building on top of Sofirn 1.0 or BLF-LT1-A2.
FYI there’s also an Orange LT1 with rev 5.8. That makes three new variations since rev 5.0
Yes Yes Yes! About a week ago I was starring at my LT1 I have mounted on a tall tripod stand & thought I’d rather a bigger lantern than a smaller one. Something with 4x 21700 or 26800 heaps of mAh’s….heaps of lumens if desired like 1-2000. Something that wasn’t focused on fitting into a hikers backpack instead focused on a camper who has a truck, tents and sets up a campsite. A light you could use for 4+nights, can be quickly topped up with the latest fast charging, maybe have some powerbank function. Just a BIG fk-OFF version of the LT1. I’d buy a couple and pay good money for them. It would sell too as most lanterns have a minimalist approach i.e they are tiny, have tiny cells and to maximize run times have tiny Betty & Jim LEDS that don’t sustain much light output. I must say the LT1 is definitely better than most of them, I’d just like bigger.
Is it normally Orange when the BLF LT1 Sofirn 1.0 is turned off or turned on? Does it only turn green when it has finished charging?
Yeah the light is normally orange when it’s off/standby. It only turns green when it is finished charging. Seems to be the same behavior as the old LT1 I was featuring in my other posts in this thread. From what I understand only the other version has the green standby light, which seem to have all been orange-body models? Not sure if there’s a correlation, or if I’m mistaken with that. Nevermind!
This is the link I ordered it from, with “Black-NewVersion-with-Battery” selected:
https://sofirnlight.com/products/new-version-blf-lt1-lantern-with-anduril-20-power-bank-function
Sorry to disappoint, but unfortunately there is no such correlation (it would be too easy :smiley: ). For instance, I also have a black unit, ordered directly from Sofirn’s webshop using the same URL you did. And it’s based around the BLF-LT1-A2 driver. Same for the guy on reddit. He also has a black LT1 w the BLF-LT1-A2 driver and green standby light. Actually, at the time when he and I ordered ours, the orange color option was not even available yet.
Dang. Should have looked more carefully. Thanks for letting me know!
