【Add a 18350 Tube】Wurkkos HD15/HD15R USB-C Dual Emitters Rechargeable Headlamp(Update)
Seems like the driver has a vertical board. There might be a chance that the attiny is accessible through the switch cutout. Like I did with the SC31Pro: Sofirn SC31 PRO, New Anduril Flashlight - #308 by SammysHP
I’m sure it does have vertical board. I’ll try to open it next week and update results here.
Will there be an option for a short tube add on with Amazon?
For improvements, JaredM covers everything i would like to see in an improved version, especially regarding the optics being Carclo or at least Carclo compatible, a one way clip (no 2-way clip needed, it gets caught on everything and no one is putting a 21700 light on their hat lid), and raw anodized finish!
So is it regulated? Buck driver?
I believe it’s FET + Buck charging circuit
Thanks for the review Funtastic. Excited for mine to arrive. I’ll want to test parasitic drain and verify the battery cut-off voltage is good. BTW, now I’ll hear your accent whenever I read one of your comments.
Haha. I did test parasitic drain in the last chart at the bottom, just didn’t get round to testing the LVP.
Thanks!
:person_with_crown: Thanks
Thanks for the review.
trying new colors of TS21 :sunglasses:
Yet you failed to answer what type of driver is in…
I don't care what's on their mind... What I see is a lot of bla, bla and not enough facts.
I'm not, no worries.
Just as one member here said "flashlighted out" so I just don't care anymore about bs when you see one. Being a specialist in "flashlight colour" means nothing.
So, once again, dear Wurkkos, what driver you have in TS21?
Might get your answer from Sofirn since they make Wurkkos' lights
My guess also...but why are you answering?
Is this not a forum where everyone can comment?
I'm a dealer for both Wurkkos and Sofirn, I also heavily reviewed the TS21 and it is using a FET driver, what more would you like to know?
Of course, you can but I'm still waiting for an answer from the right person.
We are aware of what you do so since you are not building these you are not sure either or maybe you have disassembled one....?
