PM sent, please check it out.
Mine showed up yesterday. Thanks!
All the Best,
Jeff
Sofirn - why did you use an alternating frequency strobe? You have lost sales to light painting photographers again. Please use constant /single frequency strobes.
Thank you for your support! :innocent:
Thank you for your kind suggestion!
I would like a code, please
I would like a coupon code, please.
Two on the tail cap, Both are forward click type. One (Main - mechanical) goes to Turbo directly - it’s momentary unless you do a full click. Tthe second (mode, an E-switch) activates Strobe directly. Hold the second switch in for more than 2 seconds and strobe stays on.
Then, if the main rear is fully clicked in, the second tail switch acts as a mode changer.
The cable remote switch duplicated these two switches. The long portion goes directly to strobe. the small raised bump goes directly to Turbo.
Then there is a side switch on the head that can act independently from the tail switches or in conjunction with them.
It’s a way different UI than other Sofirn or most anything else. Takes some getting used to.
I’ll have a review up in a few days. Just finished the Turbo run time test. Need some beam shots after it gets dark.
All the Best,
Jeff
PS, for some reason mine didn’t have the USB-C charging cable included in the box.
Yes, here it is: E4QQ-JD2JWP-RGDPA7
Enjoy it!
Yeah, I’ve sent you the code for TF84 several days ago, is it invalid? Here is the new code: E4Q4-9TTMLC-4ULVAJ
Any questions, please let me know!
May I have a code, please?
Thank you.
Code please.
Thanks for your comment. Here is the code for TF84: E466-4F3JHD-H3GRAD
Enjoy it! And if the code is not valid, just let me know.
Thank you.
Code for TF84: E4M7-VHHWGZ-MBZPAH
Any other questions, please feel free to contact me. Thanks!
Code please.
Ordered. Thanks
That looks like a Windows 95 CD Key.
Code please
I just put up a review of this light found here:
A well built light with a unique UI that lends itself to tactical applications. An 18650 light with USB-C charging and a remote tail switch option. A quick look at the Sofirn TF84. I got this from Amazon with the discount code for $30. Thanks Sofirn! https://www.amazon.com/sofirn-Rechargeable-Tactical-Flashlight-Pressure/dp/B08YX5SNYC/ref=sr_1_1?dchild=1&keywords=sofirn+tf84&qid=1626466619&sr=8-1 The light arrived packed in a cardboard Sofirn box, rattling around inside a larger Amazon box wi…
Also see Lux-Perpetua great review in the same forum.
Another great light from Sofirn.
All the Best,
Jeff
PM sent, thank you!
Code please
Thank you so much! :innocent:
(REVIEW) Sofirn TF84 - another review
Also see Lux-Perpetua great review in the same forum.Another great light from Sofirn.
All the Best,
Jeff
