fasttech
(fasttech)
July 13, 2021, 7:36am
1132
A cute headlamp—-Hand Wave Activated LED Headlamp w/ Hollow Reflective Headband
6-mode / 270LM / pure white / red light warning / yellow fog lamp / USB rechargeable / IPX6 waterproof / angle adjustable
2m impact resistance
Overcharge and overdischarge protection
fasttech
(fasttech)
July 13, 2021, 7:48am
1133
Another headlamp I would like to share is 6*LED 9-Mode 250LM LED Headlamp
pure white & red warning light / USB rechargeable / hand wave activated / IPX4 waterproof / power display / 60’ up & down adjustment
fasttech
(fasttech)
July 14, 2021, 10:09am
1134
1*LED 5-Mode 2300LM LED Flashlight w/ Focus Zoom
pure white / 1*18650/1*26650 / lanyard / IPX4 waterproof / USB output
fasttech
(fasttech)
July 15, 2021, 6:07am
1135
6-Mode 800LM Dual Light LED Flashlight w/ Focus Zoom
pure white & red & blue light / 1*18650/3*AAA / magnetic tail / water resistant
fasttech
(fasttech)
July 15, 2021, 6:09am
1136
3PCS SMILING SHARK K07 LED Headlamp
1*LED + 2*COB / 4-mode / 80LM / pure white / USB rechargeable / IPX6 waterproof
fasttech
(fasttech)
July 16, 2021, 9:59am
1137
Upgraded Solar Powered Rotating Color Projection Lamp for Outdoor Garden
3*LED / 2-mode / RGB / IP55 waterproof / 2400mAh battery
Solar panel: polycrystalline 6V 250mA 1.5W
Rotation method: reflective prism rotation (will not break)
Switch position: 2 mode switch (winter and summer mode)
Illumination range: 3-4m
Light-emitting mode: RGB (red, green and blue light motor rotating lens emits alternating color light)
fasttech
(fasttech)
July 16, 2021, 10:01am
1138
3*LED / 1-mode / RGB / 500mAh battery
Solar panel: Polycrystalline 5V 80mA 0.4W
Rotation method: lamp bead plate rotation
Switch position: 1 mode switch
Illumination range: 1-2m
Rotating motor: 3V long life, brushless DC motor
Working principle: It is dark, the light is controlled to start, the motor drives the red, green and blue lamp beads to rotate, and the light passes through the reflective lens to project a rotating colored light
fasttech
(fasttech)
July 19, 2021, 6:28am
1139
Convoy M21B LED Flashlight
1*Luminus SST40 LED / 4-mode / 1500LM / neutral white / water resistant / 1*21700/18650 / anti-skid body
Head diameter: 35.7mm, Tail diameter: 27.1mm
fasttech
(fasttech)
July 19, 2021, 6:31am
1140
Convoy M26C LED Flashlight
1*Luminus SST40 LED / 4-mode / 2300LM / natural white / IPX8 waterproof / 1*26650 / anti-skid body
Voltage: 3-4.2V
Head diameter: 55mm
Tube diameter: 33.5mm
Tail diameter: 33.5mm
fasttech
(fasttech)
July 19, 2021, 8:03am
1141
fasttech
(fasttech)
July 20, 2021, 3:18am
1142
New Arrival! 5*LED 4-Mode 9900LM LED Headlamp
pure white / 1*18650 / 90’ up & down adjustable / IPX46 waterproof
Voltage: 3.7-4.2V; –7’C cold & altitude 5000m challenge
fasttech
(fasttech)
July 20, 2021, 5:55am
1143
Convoy M3-C LED Flashlight
1*Cree XHP70.2 LED / 4-mode / 4300LM / 5000K / 1*IMR26650/IMR18650 / IPX6 / built-in temperature protection
Reflector diameter: 40mm
Head diameter: 48.1mm
Tube diameter: 35.6mm
Tail diameter: 38.1mm
Voltage: 3.7-4.2V
fasttech
(fasttech)
July 20, 2021, 6:23am
1144
Convoy S12 LED Flashlight
3*Luminus SST-20 LED / 4-mode / 2300LM / neutral white / water resistant / 1*21700/18650 / anti-skid body
Head diameter: 34.6mm; Tail diameter: 27.4mm
fasttech
(fasttech)
July 20, 2021, 9:51am
1145
Today’s new arrival flashlight—-YUPARD Diving LED Flashlight
1*LED / 1-mode / 350LM / pure white / 2*26650 / 50m diving depth
Head diameter: 64mm; Tail diameter: 38mm
fasttech
(fasttech)
July 21, 2021, 6:47am
1146
1*LED+1*COB 4-Mode 350LM Handheld LED Flashlight
pure white / micro-USB rechargeable / 3500mAh power bank function / power display / water resistant
fasttech
(fasttech)
July 22, 2021, 6:49am
1147
Red Light Therapy Device for Face Body Skin (US)
deep red 660nm / 338*LED
This product treats the whole body with light, reduces wrinkles and strengthens collagen.
338pcs LED, super size, relieve muscle soreness, etc.
Enhance energy, better sports performance, help build muscles and increase strength.
Helps sleep deeper and reduces anxiety.
It is recommended that the time of use should not exceed 10 minutes each time, and the number of times of use should not exceed 2 times a day. Please wear black goggles when using it to reduce the discomfort of the light on the user’s visual pupils during work.
fasttech
(fasttech)
July 22, 2021, 7:03am
1148
Convoy T2 LED Flashlight
1*Nichia 219C LED / 4-mode / 320LM / neutral white / 1*AA/1*14500 / IPX8 waterproof
Head diameter: 21mm
fasttech
(fasttech)
July 22, 2021, 7:32am
1149
I recommed you a small gadget Key Shaped Mini Outdoor LED Flashlight Keychain
1*COB / 15LM / white light / 2*CR2032
Voltage: 3V
Application: cave exploration, daily carrying, camping, patrolling, teaching, hunting, hiking, search, night fishing, night riding
fasttech
(fasttech)
July 26, 2021, 5:48am
1150
TANJE S828 Handheld LED Flashlight
2*LED / 3-mode / pure white & yellow light / 1*18650 / double head / water resistant
Head diameter: 46mm
Tail diameter: 46mm
Voltage: 3.7-4.2V
fasttech
(fasttech)
July 27, 2021, 1:29am
1151
New Arrival SMILING SHARK FB-L18 LED Flashlight
1*LED / 5-mode / 500LM / pure white / 1*18650 / IP66 waterproof / window breaker / power display / heat dissipation
Head diameter: 35mm
Voltage: 3.7-4.2V
Double control tactical switches
