I have them both the FF STL-V-6 and the the SR-STL-V2 they throw the same and they sure are hard to beat, for the money....
Hi friend, in your opinion FandyFire STL-V6 CREE XM-LT6 2 has a stronger throw than Fenix TK35 ? For mi it is important to know it. Thnaks
A TK35 is not even in the same league as the FandyFire STL-V6. The Fenix TK35 is not really a 200yd thrower. I had one and got rid of it. The Jetbeam BC40 will out throw a TK35.
Are you sure that Jetbeam BC40 has a stronger throw than TK35? Did you test the TK35? Thanks for your news.
Is it just me or is the fandyfire stl-v6 the same as the trustfire t1? http://www.lightmalls.com/trustfire-t1-cree-xml-t6-1600lm-hight-brightness-long-range-torch-light-2-x-18650
Yes. The BC40 I had though had a smooth reflector. On the op ones it may not be the case.
No that has a smaller head and reflector, but is a good light
It looks like it. May be it is the same :)
I have a Trustfire TR-1600 that is just like that one. It won't touch the STL-V2 or STL-V6.
What do you mean?
Guys,
I'll put it to you like this. And Rick tried to tell me about a year ago. I didn't listen to him at first. I just kept on buying other XM-L throwers.
Take my word on it. Rick and I have most of all the good and higher priced XM-L throwers. And none of them for the money spent will beat the SkyRay STL-V2 or FandyFire STL-V6. That includes the Olight M3X, Crelant 7G5, Fenix TK41, Olight SR51, ThruNite Catapult V3, Sunwayman T40CS, or Sunwayman V60C. Heck even the Uniquefire UF-V2 for the money is a very nice light. But the FandyFire STL-V6 I have is probably in my top 3 XM-L throwers.
And remember I said for the money above.
I never said it would out throw the Crelant 7G5 so don't ask.
I love throwers and I can't find any way to justify getting another one because of the performance and price of my Skyray STL-V2. Really if you just need one thrower get this and you are done. If I ever see a good deal on this light I'll probably pick up another one just because it's too good to pass up.
The FandyFire STL-V6 is 9 and 3/8" in length and weighs only 12oz with 2 18650 batteries.
Thanks Brad... It was hard to believe what the FandyFire STL-V6 could do against $100+ lights so I bought the SkyRay STL-V2 for $10.00 more and they are the exact same light and these boys can throw with the best of of them!!!!
Rick,
Any light as I have already told you on the phone last week that gives the M3X all it wants and then some at 100yds to where I have trouble as you know when I was telling you the better thrower is one bad light. You can buy almost 3 of the FandyFire STL-V6 for what you pay for 1 M3X. And if the M3X does out throw it it is by maybe just a little bit.
I have just known there are the new barreties: LC Protected 18650 Rechargeable 3.7V "3600mAh" Li-ion Batteries
Can I use them with FandyFire STL-V6 or ... which battery can I use?
That's what I kept trying to tell you. It is so close that your looking at them for a long time trying to pick a winner.
I use TrustFire 2400 18650, or Hi-Max 2600 18650.
Those "3600" mah 18650s are rip offs. They are overrated and a 3100 mah battery would have much more capacity. With those you would be lucky to get 1000 mah out of them.
