It really would’ve been nice if the color control was made as a menu shunt off of the main Anduril UI menu. Anduril is so rich… and sacrificing that for temperature control is too much of a disappointment. If it doesn’t sell well, maybe Lumintop will reconsider this for a replacement.
Well, with primary Anduril 2, you get a light in Simple UI mode and the user can simply stay in Simple. It’s actually quite nice. But it would be nice to then add the 2 separate emitter cluster controls as another menu item. And also make that available in Advanced. So if a light is equipped with 3 emitters, it’ll be 2 groups where one has emitters #1 & #2, and second has just emitter #3. And with 4 emitters, two sets of 2 emitters. Doesn’t matter what tint. But if a light is designed with 2 sets of different temperature emitters, they’d be mounted in the predefined groups for independent control.
So it would probably need its own version of Anduril, if it can run it. We would need to see the other side of the driver too, to see if it has an ATTiny85 chip or not. Would you be able to show that?
Yeah, I take back my earlier comment. Leds can be swapped but this ui and heavy thermal step-down are big issues. A shame, as lumintop finally got 900lm sustained in the fw3x not long ago.
