HD-2010 2 x 26650 mod.
XP-G2 Copper pill P60.
Mini C8 AAA XM-L U2 Mod
New Build/Mod. Can A Humble Defiant 3C Trounce The Mighty TN31?
Defiant 3C MT-G2, 4 x 26650 custom build.
Defiant 3C Armor Max MTG-2 mod.
Latest mods on top in each category.
_
Builds that are just not straight forward:
Building a high CRI flashlight with copper mounted sinkpad. Price about 4$ (with beam/CRI shots)
Basically, mounting a Nichia 119 on some copper pieces, the harder wayā¦
Saik SA-305 rebuild. The Fat Flooder!
5x XP-Gs, oversized pill, 32600 battery (or 3xAA)
Rebuilding a vintage German WWII Daimon with modern LED
1 XM-L, 4XAA, fairly stock looking
Making a cheap 3xAA sized P60 host
Super cheap and easy with the right tools, but does not use a stock P60 reflector.
Making a cheap bling AA sized P60 host
_
DIY:
Making Nichia 119 MCPCB - The easy way
How I re-flow emitters on a cooking plate
_
Various:
New 612 Mod and Review
Modified pill for 20mm Copper mcpcb. Swapped out emitter, driver and lens.
Post about how I modded my ZY-T13 with a trim-pot
Mostly explained with a few pictures.
TR-3T6 mod (Wallbuys lights, not the most common driver)
This thread is a bit messy. Started out as a resistor mod thread where I ended up to replace the driver and emitters to get the the desired output, modes and tint. Which basically was the plan from the beginning.
Mods by dorpmuller
New favorite flooder with pics
https://budgetlightforum.com/t/-/946
Rolled my own triple XP-G P60 PIC ADDED
https://budgetlightforum.com/t/-/1069
Latest triple I did up.
https://budgetlightforum.com/t/-/1290
Lookit this!!
https://budgetlightforum.com/t/-/1491
Mag mods and a "linger" XM-L flooder
https://budgetlightforum.com/t/-/3339
Super Mag & SWM mods-Neutralizers I & II
https://budgetlightforum.com/t/-/4219
Meet "Little Nellie"
https://budgetlightforum.com/t/-/5526
Neutralizer II
https://budgetlightforum.com/t/-/7167
Little Nellie goes to the beauty shop (and meets a companion!)
https://budgetlightforum.com/t/-/7404
Rich, we miss your mods... and you.
Match
Mod Results Part 2 ( beam shots) Good News!
https://budgetlightforum.com/t/-/895
2C Mag Mod (Lots of pics)
https://budgetlightforum.com/t/-/910
Match's Mods: Junk light to side switch P60 Host
https://budgetlightforum.com/t/-/1091
Match's Mods: Streamlight Scorpion Mod - Will it Host?
https://budgetlightforum.com/t/-/1184
Match's Mods: Modding the $1.68 BLF Delight / MXDL 1w
https://budgetlightforum.com/t/-/1254
Match's Mods: 3XP-G modded Mini-Maglite (version 2.0)
https://budgetlightforum.com/t/-/1282
Match's Mods: Edi-T T11...To He(xm)LL and back
https://budgetlightforum.com/t/-/1424
Match's Mods: 15min mini mag mod
https://budgetlightforum.com/t/-/1513
Match's Mods: 6x XML Maglite project
https://budgetlightforum.com/t/-/1628
Mini-match gets infinite brightness via QTC
https://budgetlightforum.com/t/-/1743
Match's Mods: Homemade Integrating Sphere
https://budgetlightforum.com/t/-/1948
Match's Mods: 3xXML MagMod - The RogueFlare
https://budgetlightforum.com/t/-/1961
Match's Mods: Make your own custom flashlight (no lathe!)
https://budgetlightforum.com/t/-/2037
Match's Mods: The "Woot-Lite" 2D Magclone (part 1)
https://budgetlightforum.com/t/-/2278
Match's Mods: Budget P60 Host Extreme Makeover
https://budgetlightforum.com/t/-/2437
Match's Mods: Tank E07 - Match Edition
https://budgetlightforum.com/t/-/2643
Match's Mods: Emitter to Copper Reflow in a 1C mag mod (How To)
https://budgetlightforum.com/t/-/7165
We miss you too Match
Modders, Please feel free to post a list of your mods here. I know there are many of you and I will try to add to the list, by searching threads, but only as time permits, so you can help me a lot by listing your mods in a post here.
Thank you
The Raven, copper finned Minimag in Black.
MRTdiverās custom Minimag 14500 copper
Plumbers fins AAA 10440 Minimag copper
How small are you? 3- mode Solitaire
Mum wants a Solitaire, Mum gets a Solitaire
My current project, chopped AA, AAA, and Solitaire
Midsize Minimag, two pill or not two pill.
Direct drive, direct solder, aspheric thrower in a small package.
Solitaire-qtc fail, 7135 hotwire success
JohnnyMac
Mac's Mods
Mac's Mods: Micro "Mac"-Light
https://budgetlightforum.com/t/-/2724
SAiK SA-305 WW XM-L Upgrade
https://budgetlightforum.com/t/-/5459
Easy stand lanyard mount (picture heavy)
https://budgetlightforum.com/t/-/4191
Two new MicroMags!
https://budgetlightforum.com/t/-/6818
How to make a holster for a chopped AA MiniMag (MicroMag)
https://budgetlightforum.com/t/-/7583
Adapting 20mm driver pill to 17mm
https://budgetlightforum.com/t/-/13050
Fun with hand tools
https://budgetlightforum.com/t/-/13767
$2 DIY bench power supply for testing emitter and powering a hobby charger.
https://budgetlightforum.com/t/-/17176
First Mac-Lights triple XP-G2 - the "Zombie Lord" in NW
https://budgetlightforum.com/t/-/18404
I rarely take pictures when in the process of modding, but in the future I will take more photos of the process.
Thrunite t10 to nichia: https://budgetlightforum.com/t/-/18074
p60 L2M 18500 TIR build:
p60 triple nichia219 drop-in:
Hereās my one Mod I did. I did it to fill a need I had. Full flood single 18650 high CRI headlight. It worked so good Iāve been out of the headlight market for awhile now. I still use it as my daily light at work and at home.
UF-H3 modded with a Nichia 219 Best 18650 Headlight ever
Updated 06/14/15
Modders, please feel free to post your mod links here, for easy access to all members.
This is my first BLF build.
My second BLF build is a Dorcy lantern mod outfitted with a DC-DC converter with custom firmware that allows for the selection of 6 brightness levels.
Nice bump! Iāll delete this once this gets going again:)
Some stuff Iāve done.
Convoy S2 Shorty Rechargeable Mule
Convoy S6 Triple USB Rechargeable 18350
Cooyoo Quantum mule with Tritium Momentary Switch
CQG S1 Mods - Twin Set - Flashlight & Sidelight
CRX - 1000p Carbon Fibre & Brass Flashlight
CRX - Old Lumens Scratch Made Light Contest Entry
Eagletac D25C Triple Forward Clicky
FourSevens Atom KeyChain Light Mod
FourSevens Mini ML Ti Triple & Tailswitch Mod
Graphitized some more small lights
Handmade AAA Copper Tube Light
Handmade Copper P60 - Quad Nichia
Mini Monolith Dual LED Dual Switch Flashlight
Nitecore EA4 Tailcap Lockout Mod
Nitecore EA4 Ledil Cute optic triple Nichia 219c
Olight TC15 MT-G2 Battery Tube Light
Rofis JR10 triple XP-G2 to 18500 cell and MTN FET
Smallest MT-G2 Flashlight Ever?
Smallest XHP50 Flashlight Ever?
Sunwayman V10R Ti with Graphite Battery Tube
Thrunite Ti2 UV 10180 & Tailswitch Mod
Thrunite T10T triple XP-G2 & FET driver
TrustFire Mini 01 Tail Switch Mod
Ultrafire UF-10 to 16500 & FET Mod
Thread revival!! :laughing:
Iām gonna throw my hat in the ring here. Some of these are before i had a lathe
sbt70 aspheric build 16/5/14
Good host for you 18/7/14
KD's big reflector in a tk61 16/3/15
WTS tk61 modded with xhp70 18/12/15
Mechanical mod - mod 24/6/16
Quad xhp35 23/4/17
Copper DQG26650 8/6/17
Colour modded V4A 7/8/17
High power UV 7/11/17
Stripey little mtg2 17/12/17
27100 tube light 9/2/18
Car mounted hunting light 2/5/18
Holy tail 22/6/18
Headlamp build 16/8/18
dqg18650 mods 11/10/18
6th OL comp build 4/11/18 ā¦and later modifications 8/2/20
Ti and Mokume build (Timo) 13/1/19
UF2100 re-skin 15/2/19
Monkey kingās staff, vape conversion 21/3/19
Vape conversion #4 4/6/19
Mokume build 15/6/19
Big quad build 2/8/19
7th OL comp build (superconductor) 22/9/19
Holy head vape conversion 2/12/19
The first fw3d 28/1/20
Programmable infinite mirror tail 6/4/20
McGizmo side lights 23/5/20
Emisar D4 infinite mirror tail 24/8/20
Copper build 12/9/20
Mokuti build 7/2/21
fw3 - mokuti 13/4/21
Chinese hair clipper conversion
youtube(dot)com/watch?v=9Z-GinsLhao 1/5/21
Sunwayman v11r lighted tail
What did you mod today? - #9951 by pinkpanda3310 8/5/21
Illuminated skull eyes 5/7/21
There might be 1-2 i missed and/or smaller stuff in the āwhat did you mod todayā thread but this is the majority. Hopefully more to come
Skull rings 11/8/21
Dragon rings 4/9/21
Glow skulls on E14iii 29/9/21
Copper-brass P60 27/11/21
21700 P60 Mokuti 21/5/22
Great work PP. I just watch the FW3 video. Beautiful light. I have bad hearing so I could not hear you well over the music though.
