“REVIEW”: Lumintop FWAA – 14500 – Anduril 2 – Triple Nichia 4000K & 5000K [Pic Heavy]
I agree, and hope some accessories come along, including a better clip with deeper carry, and a glow gasket
suggestion to test
if you move the clip between the head and body (and if the light still turns on)
it will make the clip slightly more deep carry, but still not tight grip.
I would use the clip under the head, if it made contact, but no luck.
I stayed up late learning to set ceilings and floors.
1. My simple mode now has a ceiling of 200 lumens (72 steps down from 150), and 24 steps, just like an HDS. That max output is sustainable, does not trigger thermal step downs. I like this sustainable output option.
2. My advanced mode now has a ceiling of 550 lumens (50 clicks down from 150). also 24 steps. That max output is NOT sustainable, it triggers the 45C default thermal step down, and goes down to 90 lumens, sustained… Not ideal.
3. I set manual memory to 10 lumens using my light meter (it is step 10 of 24)
4. Calibrated the thermosensor, am still using default 45C thermal step down.
5. Battery check is great, it reads 0.1v low, which I like. Im leaving voltage calibration stock.
6. To determing when Im in simple mode, I do a battery check, 3C from off. IF the battery check turns off after the first readout, the light is in Simple… IF the batt check repeats in a loop, Im in advanced.
At this point, the practical difference between advanced and simple (besides ceiling), is that when I want to use a strobe to alert traffic, while crossing the street, I must be in advanced. I have strobe set to bike flasher, there is no strobe in simple.
I have zero interest in any of the candle and lighting modes… random flickers and flashes really bother me.
FWAA Anduril2 non standard commands trivia:
1. the temperature config position in the menu, it comes 3rd, after battery check and beacon
2. in advanced, 2C gives ceiling, but a second 2C does not work to go to Turbo. I dont mind… 1000+ lumens of Turbo for 3 seconds is not necessary for my application. Momentary Turbo is still available from Off with 2H
Here is an edited Lux Perpetua FWAA Anduril 2 UI flow chart:
I made 3 changes, in blue…
  1. moved FWAA temp config to 3rd position
  2. blocked out 2C to turbo in advanced, with a blue box
  3. I put the number 3 instead of a 2, in the ceiling and floor config menu, for the step count
Im enjoying the FWAA very much, presently running in Simple Stepped mode with the body tube reversed (gives a better grip imo):
I painted some glow paint around the inside of the head (onto the plastic ring). It works, but a properly fitted glow gasket would be better.
Sorry, I guess I explained myself wrongly. When I meant under the bezel it was really under the bezel, not between the head and tube.
I am not sure if it can be done in the Cu version…
As for running it with the tube inverted, I tried to do it on mine but it doesn’t turn on. I guess it may be related to the internal tube, eventually.
I am glad you are liking it and that you “found” your optimal confirgurations for it :wink:
BTW, will it receive some Nichias anytime soon? :wink:
Wow!!
Great idea!
I knew if I asked here. I’d get the right answer
The clip under the bezel REALLY gives it the retention needed
THANK YOU!!
thanks for the photo,
that option is a bezel up carry… will think about it…
under the head would allow bezel down carry…
Have not decided what LED mod to use yet, the SST-20 is pretty nice as is.
before I decide…
Im waiting for azhu to restock 219b 3500k, which is slightly more pink than the SST:
hard to capture in a photo, the difference that I see with my eyes. The SST is slightly greener and cooler than the 3500k 219b.
The SST is not obviously green, like I feared. Its quite nice.
Cool, glad it helped :wink: It was an experience but I am actually fond of it too!
Yup, this option I’ve shown is not suitable for bezel down carry, it would need to be a longer clip for that.
I do like, though, that it won’t burn pockets since it is bezel/light up. It can activate accidentally, of course, given the switch can be pressed by things inside the pockets. There is no perfect solution with this clip :zipper_mouth_face:
Hum, I only have 2 lights with SST20, but I guess all of them will always have some green that the Nichias don’t have.
A 3500K Nichia will look great on that Cu version, so if you go for it, please show it to us then :wink:
:beer:
yay!
did putting the clip under the bezel, reduce the pressure on the lens?
(compromised water seal)
Did you add an extra lens or O ring to make up the gap created by the clip lifting the bezel away from the optic?
It does reduce the pressure, so it is advised to use an extra o-ring under the glass less (between that and the optic), or get a thicker lens :wink:
yes
the internal tube has a lot of resistance to sliding towards either end
by tightening the tailcap onto the “head” (the flared end) of the body tube, with the clip installed, I was able to push the inner tube towards the “tail” (not flared). Now it works with the head on the flipped body. As pictured: (light is ON to show it works)
Hey jon_slider, congrats on getting your first Anduril UI flashlight! And thanks so much for the comparative beam shot photos. I’ve got one of these on the way as well. Very encouraged by the emitter tint. I was worried there might be a greenish tinge but it’s obvious that it’s more golden in color. A nice pale golden that’s closer to neutral than it is to full-on warm. That’s pretty much what I’ve been looking for in an AA sized EDC. There’s also something nice about sleek copper like this, as opposed to chunky, busy designs.
exactly right, pale gold for the 4000k color temperature
and very neutral tint,
it is an overcast day, the SST-20 does not look green at all
and flipping the body is fun too :wink:
all but the FWAA SST-20 4000k have sw45k mods
info request for Customized Anduril 2 for FWAA
I would like to learn more about what is needed for me to be able to reflash the FWAA firmware
besides my own custom ceilings, I want to turn off the double blink in the ramp, and make the ramp half as fast.
can someone point me in the right direction…?
my custom FWAA settings wishlist
Anduril reflashing required:
(workaround is to use stepped mode)
double blink OFF
ramp speed 50%
Custom UI configurations:
advanced ceiling 90/150 (400 lumens)
simple ceiling: 78/150 (200 lumens)
thermal limit 40C
memory set to 15 lumens
hybrid memory set for 90 minutes
12 stepped modes
I got notice that FWAA glow gaskets are available
despite the price, I was about to pay, but, there is no paypal option, so I have not followed through
maybe others will be interested…
I’ve purchased multiple lights/items from Jared and never had issues. He’s awesome to deal with. He got burned once from paypal, that’s why he doesn’t accept it anymore.
That being said I already have two on the way lol.
congrats, the glow gaskets look very nice
Today I took the bezel off my FWAA, in order to paint glow onto the mcpcb… I also polished the lens. Output went up 9% and there are no bad beam artifacts.
the previous coat of acrylic paint around the inner bezel (post 128), peeled right off when I removed the optic. No problem there.
(the pro photogirl I hired in my dreams, did not show, so I had to take my own blurry pics…)
the glow paint that peeled off the inner bezel, fits around the tail, so just for fun:
However, a tiny screw fell out of the driver. I put it back. I do not know if that free floating screw had anything to do with my Runaway Ramping issues with the FWAA, during assembly.
So far there have been 3 QC issues with my Cu FWAA
1. The screw fell out of the pill. now fixed
2. The retaining ring for the driver was halfway unscrewed. now fixed
3. One of the LEDs is dimmer than the others… have not tried to fix it… the light is still plenty bright, and the beam looks fine.
Jon, can you explain how you polished the lens? Think I’d like to try it on mine. Thanks.
I really enjoy having a GITD optical insert in my FW3A so I’d like to pick up one for the FWAA at some point. I’m hoping that eventually Neal or other more established sellers will be offering them. I had seen someone buy an early GITD from a small time seller for the FW3A and it didn’t have good glow power. The green one I got from Neal is super bright.
Is it possible to put in a GITD o-ring around the perimeter of the optic?
Also you mentioned polishing the lens… do you mean the sapphire replacement that Neal is offering, or the original?
I used Sunshine Cloth to polish the top of the plastic FWAA triple optic.
I put the sunshine cloth on a kleenex, on my desk, and holding the optic in my hand I rubbed it against the flat polishing cloth. A few strokes in different directions, including a few circles… (few= 5-10 swipes… )
I use Sunshine Cloth to polish my Ti lights … works very well for copper too.
Nice work! I’ve not tried the Sunshine Cloth before. Is it less abrasive than something like the Cape Cod polishing cloth
I do not know the relative abrasiveness. Cod Cloth ingredients seem to include mineral spirits and vanilla… Sunshine cloth has neither volatiles nor aromatics.
I like the Sunshine yellow because it works faster than red rouge, while still leaving a very high gloss polish, not too abrasive.
I made a short 2.5 minute video including a beamshot comparison of the sst20 4000k version of this light vs the aaa sofirn C01s (sst20) lumintop tool aa (4500k) Emisar D4 (sst 20 4000k) and the emisar D4V2 (XPL-Hi 5000k)
