Maybe SIGShooter has some background info (?). I mean it was not exactly a secret that a reverse charging variant was coming. And it was SIGShooter who published that info in the LT1 topic more than a year ago.
My bets are this will be more vaporware, but I’ll keep my fingers crossed. Has anyone from Sofirn discussed when these might go into production?
Also, did they include you in the prototype phase, or are they going to skip that and move ahead by themselves (as they have done with subsequent LT1 changes)?
Barry of Sofirn has been in contact with me much more lately for future designs, as everyone know i was in a bit of a hiatus during my move and illness the past year. Lux-Perpetua has introduced a design based from my original LT1-Mini & refined in the design group chat, and things are looking positive for the LT1-Mini, LT1-Compact, and LT2/21700 versions.
Thanks for the update. I hope you are feeling much better these days and life has returned (more or less) to normal.
It looks like the 8 x 18650 LT1 adapter never got off the ground. Its too bad that such a cost effective, simple and useful add-on made it through the prototype stage but never went into production. Id have purchased several. I always wondered what the LT1 and possible upcoming variants and accessories might have been if they had been produced by Astrolux or Convoy. Ah well… Im still very pleased with my collection of LT1’s and they see a great deal of use. Thanks again to all who were involved. :+1:
In Anduril 2, there is a Simple Mode feature… Still by using 1 button as opposed to your 3 button request, but more in line with the usual kind of UI found in most lights.
That is planned, for the LT2. four 21700 capability, with power bank, 3rd red LED channel.
[/quote]
That sounds awesome! I’m using my LT1 right now, I use it pretty much everyday. Would love a bigger LT2 but I am thinking big getting the new orange LT1 just because. They are such good value.
I liked that 8 x 18650 adapter as well, i was thinking of designing a larger ” wider” battery tube, to hold up to 8 - 18650s in parallel, and would ad stability to the LT1 lantern head. ( and look much like how the base/tank of a Coleman gas lantern is. * Hey Barry! are you listening to these ideas? make it a reality!
So possibly a large 8 x 18650 base that would screw onto the existing 4 x 18650 LT1 (for a total of 12 x 18650). That is ingenious and I like the way you think. And of course, Id buy several! That would also make for a great high capacity power bank.
Admittedly, my vintage Coleman lantern collecting obsession has reached new heights. All attributable to my inability to restrain myself from acquiring these finger burning photon emitters.
Could anyone please help me out, my lantern’s light output gradually decreases in time? I factory reset by unscrewing and holding the button for 4 seconds while rescrewing the body back. Then I double checked by doing 13H for the factory reset in Andruil 2.0. I then changed the tint to bright white by 3H, but the issue that when the light is on the lamp decreases the brightness until the lamp is off after 2 second increments!
That is odd… never seen that happen before. Maybe Toykeeper or Barry can chime in on that… if the driver is defective, contact Sofirn i’m sure they will help! - DB
This sounds like a weak battery (getting “low-batt” or “empty”), but if the batteries are not “low-batt” (can check using the triple-click from Off for “Battery Voltage Check” function).
If batteries are not “low-batt” (not nearing 3.0v), then it could be some poor contact issue (fully-charged batteries might be detected as “weak” due to poor contact somewhere — sometimes it could be due to an o-ring that’s entangled and interfering with the contacts).
