3PCS SMILING SHARK K07 LED Headlamp
1*LED + 2*COB / 4-mode / 80LM / pure white / USB rechargeable / IPX6 waterproof
Upgraded Solar Powered Rotating Color Projection Lamp for Outdoor Garden
3*LED / 2-mode / RGB / IP55 waterproof / 2400mAh battery
Solar panel: polycrystalline 6V 250mA 1.5W
Rotation method: reflective prism rotation (will not break)
Switch position: 2 mode switch (winter and summer mode)
Illumination range: 3-4m
Light-emitting mode: RGB (red, green and blue light motor rotating lens emits alternating color light)
3*LED / 1-mode / RGB / 500mAh battery
Solar panel: Polycrystalline 5V 80mA 0.4W
Rotation method: lamp bead plate rotation
Switch position: 1 mode switch
Illumination range: 1-2m
Rotating motor: 3V long life, brushless DC motor
Working principle: It is dark, the light is controlled to start, the motor drives the red, green and blue lamp beads to rotate, and the light passes through the reflective lens to project a rotating colored light
Convoy M21B LED Flashlight
1*Luminus SST40 LED / 4-mode / 1500LM / neutral white / water resistant / 1*21700/18650 / anti-skid body
Head diameter: 35.7mm, Tail diameter: 27.1mm
Convoy M26C LED Flashlight
1*Luminus SST40 LED / 4-mode / 2300LM / natural white / IPX8 waterproof / 1*26650 / anti-skid body
Voltage: 3-4.2V
Head diameter: 55mm
Tube diameter: 33.5mm
Tail diameter: 33.5mm
New Arrival! 5*LED 4-Mode 9900LM LED Headlamp
pure white / 1*18650 / 90’ up & down adjustable / IPX46 waterproof
Voltage: 3.7-4.2V; –7’C cold & altitude 5000m challenge
Convoy M3-C LED Flashlight
1*Cree XHP70.2 LED / 4-mode / 4300LM / 5000K / 1*IMR26650/IMR18650 / IPX6 / built-in temperature protection
Reflector diameter: 40mm
Head diameter: 48.1mm
Tube diameter: 35.6mm
Tail diameter: 38.1mm
Voltage: 3.7-4.2V
Convoy S12 LED Flashlight
3*Luminus SST-20 LED / 4-mode / 2300LM / neutral white / water resistant / 1*21700/18650 / anti-skid body
Head diameter: 34.6mm; Tail diameter: 27.4mm
Today’s new arrival flashlight—-YUPARD Diving LED Flashlight
1*LED / 1-mode / 350LM / pure white / 2*26650 / 50m diving depth
Head diameter: 64mm; Tail diameter: 38mm
1*LED+1*COB 4-Mode 350LM Handheld LED Flashlight
pure white / micro-USB rechargeable / 3500mAh power bank function / power display / water resistant
Red Light Therapy Device for Face Body Skin (US)
deep red 660nm / 338*LED
This product treats the whole body with light, reduces wrinkles and strengthens collagen.
338pcs LED, super size, relieve muscle soreness, etc.
Enhance energy, better sports performance, help build muscles and increase strength.
Helps sleep deeper and reduces anxiety.
It is recommended that the time of use should not exceed 10 minutes each time, and the number of times of use should not exceed 2 times a day. Please wear black goggles when using it to reduce the discomfort of the light on the user’s visual pupils during work.
Convoy T2 LED Flashlight
1*Nichia 219C LED / 4-mode / 320LM / neutral white / 1*AA/1*14500 / IPX8 waterproof
Head diameter: 21mm
I recommed you a small gadget Key Shaped Mini Outdoor LED Flashlight Keychain
1*COB / 15LM / white light / 2*CR2032
Voltage: 3V
Application: cave exploration, daily carrying, camping, patrolling, teaching, hunting, hiking, search, night fishing, night riding
TANJE S828 Handheld LED Flashlight
2*LED / 3-mode / pure white & yellow light / 1*18650 / double head / water resistant
Head diameter: 46mm
Tail diameter: 46mm
Voltage: 3.7-4.2V
New Arrival SMILING SHARK FB-L18 LED Flashlight
1*LED / 5-mode / 500LM / pure white / 1*18650 / IP66 waterproof / window breaker / power display / heat dissipation
Head diameter: 35mm
Voltage: 3.7-4.2V
Double control tactical switches
SMILING SHARK K225 LED Headlamp w/ Focus Zoom
1*LED / 3-mode / 1200LM / yellow light / 2*18650 / IPX6 waterproof / 90’ up & down adjustable
Spotlight mode: 1500m beam range
Floodlight mode: 50 square meters light area
USAMS US-CD166 LED Flashlight Mobile Power Bank 4000mAh
2400mAh rated capacity / 4-mode (low/high/SOS flash light/360’ ambient light) / 350LM / pure white
SMILING SHARK E666 LED Flashlight
1*LED / 3-mode / 420LM / pure white / USB rechargeable / water resistant / heat dissipation
New Arrival 5*LED 4-Mode 9900LM LED Headlamp
Voltage: 3.7-4.2V;
