Thank you for your support! :innocent:
Thank you for your kind suggestion!
I would like a code, please
I would like a coupon code, please.
Two on the tail cap, Both are forward click type. One (Main - mechanical) goes to Turbo directly - it’s momentary unless you do a full click. Tthe second (mode, an E-switch) activates Strobe directly. Hold the second switch in for more than 2 seconds and strobe stays on.
Then, if the main rear is fully clicked in, the second tail switch acts as a mode changer.
The cable remote switch duplicated these two switches. The long portion goes directly to strobe. the small raised bump goes directly to Turbo.
Then there is a side switch on the head that can act independently from the tail switches or in conjunction with them.
It’s a way different UI than other Sofirn or most anything else. Takes some getting used to.
I’ll have a review up in a few days. Just finished the Turbo run time test. Need some beam shots after it gets dark.
All the Best,
Jeff
PS, for some reason mine didn’t have the USB-C charging cable included in the box.
Yes, here it is: E4QQ-JD2JWP-RGDPA7
Enjoy it!
Yeah, I’ve sent you the code for TF84 several days ago, is it invalid? Here is the new code: E4Q4-9TTMLC-4ULVAJ
Any questions, please let me know!
May I have a code, please?
Thank you.
Code please.
Thanks for your comment. Here is the code for TF84: E466-4F3JHD-H3GRAD
Enjoy it! And if the code is not valid, just let me know.
Thank you.
Code for TF84: E4M7-VHHWGZ-MBZPAH
Any other questions, please feel free to contact me. Thanks!
Code please.
Ordered. Thanks
That looks like a Windows 95 CD Key.
Code please
I just put up a review of this light found here:
A well built light with a unique UI that lends itself to tactical applications. An 18650 light with USB-C charging and a remote tail switch option. A quick look at the Sofirn TF84. I got this from Amazon with the discount code for $30. Thanks Sofirn! https://www.amazon.com/sofirn-Rechargeable-Tactical-Flashlight-Pressure/dp/B08YX5SNYC/ref=sr_1_1?dchild=1&keywords=sofirn+tf84&qid=1626466619&sr=8-1 The light arrived packed in a cardboard Sofirn box, rattling around inside a larger Amazon box wi…
Also see Lux-Perpetua great review in the same forum.
Another great light from Sofirn.
All the Best,
Jeff
PM sent, thank you!
Code please
Thank you so much! :innocent:
(REVIEW) Sofirn TF84 - another review
Also see Lux-Perpetua great review in the same forum.Another great light from Sofirn.
All the Best,
Jeff
Still available!
Code Please
Yes, code has been sent to your message, please check it out, the discounted price is still $29.99.
Code Please
