Just purchased. $23.65 out the door, delivered via Amazon Prime.
Its big, and heavy. Great price.
The $17 soldering iron arrived today. I see it’s now $20.
https://www.amazon.com/Soldering-Function-Adjustable-Temperature-Ergonomic/dp/B08NDH4Q2T?ref=deals_deals_deals-grid_slot-15_8a28_dt_dcell_vdt_334_73179620
You get the power supply, the handle, 2 tips, a holder with brass scraper, a second holder with holes for mounting to something, ground strap, and a minuscule sponge. And lets not forget the little rubber feet that stick to the power supply and the holder.
Seems reasonable well built. Turns on and gets hot in a hurry.
I’ll see if I can find a thermal sensor that can measure temps. I’ve got one around here someplace.
LOT of warnings about electric hazard and shocks. So it’s safe to assume the thing is not isolated in any way.
Comes with virtually no instructions other than how to put the stick on feet on the body.
There is an included Allen key. No instructions on what it’s for.
It does fit the screws on the back of the case. When I have more time I’ll put it to use and take a peek at what’s inside.
All the Best,
Jeff
26650 flashglight - xhp 70, zoomie?
$11.69 before tax. I ordered it, Unfortunately 5 mode (blinkies included).
On the soldering iron. I just checked and the chassis is NOT grounded. Thus all the shock warnings.
I’ll do a review and do a mod to ground the case.
Do Not use this unless you understand the risks.
Gee, a single wire inside the case could have fixed this (I think).
I found a few of the settings. But this one is not in the same class as the $80 PID soldering irons. The main difference being the display that give basically no information other than the temperature.
Still for $17-$20? Cheap, or cheaper than a typical soldering pencil. But it needs a safety mod.
All the Best,
Jeff
Somehow I have one of those, I would prefer a titanium long spork over it lol.
Just got one of these large desk lamps
$21 with the Vipon code. Click the above picture to go to Vipon. It’s been coming and going at Vipon.
I cannot detect any visible flicker and I don’t see any banding on my Pixel 4XL camera which is horribly sensitive to flicker.
The controls work well, but they are invisible in a dark room and they have zero tactile feedback. You can’t feel the controls so you have to turn on a flashlight to see them
Also, if the lamp head is too close to the top of my monitors, the light causes a glare and washes out the top edge of the displays. Moving it a bit higher, and forward, fixes the issue.
I have it clamped onto my computer worktable.
Wow. Your computer table looks awesome. Its it the standing desk?
Best computer desk/work table I’ve ever had. Height is adjustable. Got it a couple months ago at Home Depot
And Harbor Freight has a bunch of magnetic accessories for their roll around toolboxes that work great on this workbench: power strip, screwdriver holder/tray, magnetic hooks, etc. I have one of the trays stuck on the back of my bench holding the power adapters for my monitors and laptops so they aren’t just hanging down to the floor.
Yeah, those look pretty neat. It’s one of these Husky models from Home Depot.
I have a couple electric height-adjustable desks and really like them. I was eyeing those Husky models before I found a deal on my second desk.
EDIT: TexasToasted beat me by a few seconds.
I’ve been using this since May. Price went up $20, but worth it imo.
since we are “talking” soldering iron….
code PNH269OM gets this for $13.
none of the Amazon links work.
do not know why.
please search
on Amazon.
Vastar Soldering Gun Automatic Hand-held
Pete7874, i thank you.
Tactical flashlight, 1200 lumen, with magnetic charging - $7.09
I know not many zooming fans, but received the one I got for <$12 today. Amazon Deal Alerts & Discussion Thread - #4048 by dthrckt
I suspect the led pcb is bridging a gap in the pill, pretty light Weight. Battery says icr 3800.
Case is worth a few bucks to me. Will try to remove USB charging garbage, swap lens and driver and make it 26800. I like the huge emitter when zoomed.
Zoomies are useful boat camping, and I usually end up giving the cheap mods away and stick to my FD65 (close) and HT35 (far).
Govee LED Rechargeable Flashlight, 1000 High Lumens CREE XM-L3 LED
18.99 + –40% coupon = $11.39
Another TIR zoomy.
must resist.
I put up a review of the Handskit PID soldering iron:
https://www.amazon.com/Soldering-Function-Adjustable-Temperature-Ergonomic/dp/B08NDH4Q2T?ref=deals_deals_deals-grid_slot-15_8a28_dt_dcell_vdt_334_73179620&th=1
All the Best,
Jeff
Repeat - NO MORE CHEAP ZOOMIES - NO MORE CHEAP ZOOMIES
